Retro620ti
  1. jon you remind me of me, i used to get slaughtered then phone my old man at anytime between 0100 and 0400 just to have a laugh, he didnt find it funny though.....hehe
  2. vent anytime ya want bud, feel for ya
  3. Ok lets cover the U/D pulley situation, decided to fit it today and it was going sweet as a nut until reassembly, got the U/d off danny at dta(aka smithys) and on fitting found that the tolerances for the woodruff key on the crank were too tight on the pulley side, the key would not fit in the pulley, was a pain in the ass really as I was working at the side of the road didn't have any files and couldn't get the pulley on( before you say it I am used to woodruff keys as they use them on sea king tail gearboxes, I checked the key off the car on the pulley and the fit on pulley side was too small), I ended up using some sandpaper on a flat surface and slightly removing a bit of the key to get it to fit which isn't a perfect solution( will mail you danny if you are reading this as I was cursing the idiot on the cnc who machined this one), Once fitted and running was impressed with the way the car revs and pulls in the gears now, dyno will show the results in 2 weeks. Meguiars Vs Zymol From the start I will say that Zymol has a deeper finish and works with faded paint better than meguiars, unfortunately meguiars still wins the competition though, the reason for this is that Zymol leaves a white powder residue on polishing off and is also harder than meguiars to polish off, the difference in finish between the two is minimal but that extra work and the powder from zymol lost it this competition.
  4. Heres the ecu pin info , may help with tracing the prob knowing the ecu pin outs for the coil pack.HTH 1990-1995 Nissan 300ZX Pin 1 Ignition 1 Coil #1 2 Ignition 2 Coil #2 3 Ignition 3 Coil #3 4 AAC Valve 5 A/T Control Unit PW 6 Cooling Fan Relay (300ZX Turbo Only) 7 Tachometer 8 AIV Solenoid (90-92 300ZX) 9 Air Conditioner Relay 10 ECM Ground 11 Ignition 4 Coil #1 12 Ignition 5 Coil #2 13 Ignition 6 Coil #3 14 A/T Control Unit 15 A/T Control Unit 16 ECM Self-Shutoff Power Source 17 Data Link Connector 18 Fuel Pump Relay 19 Cooling Fan Relay 20 ECM Ground 21 Diagnostics Receive Data 22 Diagnostics Transmit Data Switch 23 Knock Sensor 24 25 Wastegate Solenoids (Turbo Only) 26 Mass Air Flow Sensor Ground 27 Mass Air Flow Sensor MAF 28 Engine Coolant Temperature Sensor 29 Right Side Heated Oxygen Sensor 30 Sensor Ground 31 Diagnostics Clock EGT 32 Malfunction Indicator Lamp 33 FICD Solenoid 34 Power Steering Oil Pressure 35 Fuel Pump Voltage Control (300ZX Turbo Only) 36 Fuel Temperature Sensor 37 --- Spare Temp Input Avail, 0-5 Volt 38 Throttle Position Sensor TPS 39 EGR Temperature Sensor 40 41 Camshaft Position Reference Signal 42 Camshaft Position Signal 43 Start Signal Cranking 44 Neutral Position Switch 45 Ignition Switch +12V 46 Air Conditioner Switch 47 Diagnostics Check Signal EGT 48 Power Source For Sensors +5V 49 Power Supply For ECM 50 ECM Ground 51 Camshaft Position Reference Signal 52 Camshaft Position Signal 53 Vehicle Speed Sensor 54 Idle Position Switch Switch 55 Left Side Heated Oxygen Sensor 56 Throttle Sensor Output Signal 57 Power Source For Idle Position Switch 58 Power Supply Back-Up Permanent +12V 59 Power Supply For ECM 60 ECM Ground 101 Injector 1 102 EGR Control Solenoid Valve Idle 103 Injector 3 104 Fuel Pump Voltage Control 105 Injector 5 106 107 ECM Ground Power Ground 108 ECM Ground Power Ground 109 Power Supply For ECM 110 Injector 2 111 PRVR Control Solenoid Valve Injector 112 Injector 4 113 VTC Solenoid Valves 114 Injector 6 115 O2 Sensor Heater Injector 116 ECM Ground Power Ground
  5. side by side, depends on the native res of the users display really, im guessing your using a widescreen set up
  6. the light is lit up to tell you the autobox is stealing power from the engine
  7. how much in the motor tho bud
  8. Good man yourself, you did the right thing.
  9. cheers greg, have all the right belts, will make sure i dont stretch em too much
  10. will let you know, bit concerned by the noise problem with squealing
  11. http://www.300zx.co.uk/forums/showthread.php?t=98912
  12. Finally got a few days off so decided to fit the U/D pulley tomorrow and spend the full day on the Z getting it nice and tidy and retensioning the injector connectors, heres hoping i dont break anything, including myself, for some reason lately everytime i touch anything on the Z i end up cutting, bruising, slicing, breaking and generally hurting myself, it must be all the room in the engoine bay thats the problem.
  13. my main problem is i listen to linkin park and my driving tends to speed up for some reason
  14. really wtf was that all about.......unless theres a serious reason posted for that shite you my obnoxious friend aint ever gonna get help from me..................and as for you jonpob...lol only kidding CraigD
  15. hold wont use first when pulling off, and it does help avoid the auto shuffle by not using kick down
  16. well done bud, pics? for me stick to 18's as its still a better balance of performance and looks, i am slightly biased though as i have 18's
  17. the locking pineapples are not a ideal solution to split bushes, try the z1 locking collars which will require a small drop of the subframe to fit, this will have the added benefit of tightening up the rear end but make the road noise a bit more
  18. also look in the aol folder for a temp internet file, on a side note dump the aol browser and start using mozilla as well its so much faster.
  19. start, all programs, accessories, windows explorer, windows, temp, temp internet file
  20. use the windows explorer tab in the sys tools menu, go into windows, look in temp you will find a tem internet files folder in there , clean it out.
  21. they removed it for some reason, if you have broadband i could mail you the 3 files as i downloaded em from there
  22. i miss butter pies from growing up in lancs
  23. bourne from tv links is crap try getting it from stage6 as its in high quality divx, your welcom zxgirl
