Retro620ti
  1. dont just mess arround with the screw , theres more to it than that
  2. heat the arm and freeze the bush
  3. for a saving of 8bhp the leccy fan just aint worth it
  4. the viscous fan shifts 6400cfm of air when needed , couldnt find a electric that could match that so stayed with the viscous
  5. theres 2 ag2's one has more yellow than the other
  6. sorry its late but im gonna have to shoot through, sorry john
  7. i just feel he didnt know what he wanted, its part show car and part performance build, no clear line in the sand, i personally think that detracts from all the hard work hes put in
  8. ignore that i not on a stock spoiler so when i removed mine i might of had a different original experience
  9. easy way is go to media player, click the arrow under library , select media sharing
  10. you need to enable file sharing in your network settings , if its still as set up at the factory then it will be a private network , make it public and enable file sharing
  11. so if we just increase disc size the caliper is the same with a bracket to move it out and the abs should be able to cope?
  12. email me at kevandtrudy@btinternet.com and I will send back a full registry cleaner and startup manager program
  13. piece of piss, its a drag and drop situation, then click convert
  14. once youve got it done dan you can come do mine for me fella:wack:
  15. im putting together a whole engine removal , rebuild and reinstall web package from all the info on the net , so far i have removal done with good pictures so if you need it gimme a shout and i will try to mail it to ya
  16. do a z, just learn as much about it as possible and take your time, also take pictures of everything you do in case you get lost when putting it back together
  17. use esuper video convertor , it has a setting for psp, use the h264 format as its better quality and smaller files
  18. you gotta hope that alonso doesn't take him out on the first bend, wouldn't put it past him to do it on purpose as his temperament is suspect
  19. I have 412bhp and it pulls to 175 quite nicely, after that i ran out of balls
  20. i just hope he has a old head on tommorow, dont stuff it and just finish 5th and above , theres no need to chase especially on the first corner
  21. are you using a 3 leg puller
  22. make sure the woodruff key isnt being nipped by the pulley
