Top Speed in Z - too scared of blowing up car
ive nearly done all i want to my car, performance wise.
(apexi filter, chiped ECU, decats, full exhaust, boost jets @ 15PSI)
im estimating the car to be 340 BHP
most ive ever done in it was about 150mph, and i wasnt really trying.
im want to see how fast i can go, as 150 is the fastest ive ever gone in a car.
im aiming for 170 mph, asuming this is a realistic figure?
however i dont want to be pushing the car so hard it blows up! engine or turbos!
ive just done an oil change, and the car seems to be running ok at the moment.
what have you all managed top end from your cars? anything bad happen?
  • Replies 34
  • Views 2.1k
I've seen 181.9mph on proper telemetry gear at Bruntingthorpe in Chunk's swb slicktop TT. I Couldn't tell you what he'd got done to it at the time other than a Profec B wound up to max.
It did die a few days later though :D
My black one has stock IC's, stock injectors, POSSIBLY uprated turbos (need to double check and confirm this though) running 0.8 bar (11.76psi) and gets to 165 easy enough.
No idea on my estimated power i need to dyno it before I start messing :p
Mine will do 160 and still pulling, I would estimate 180 maybe bit more. Got same mods near enough as you and recently dyno'd at 385bhp, with 420lbs of torque:dance:
really!!!
going to get mine dyno'd!
seen 175 on the clock and still pulling strong at that.
really!!!
Ye mate, as all above and below, mine will stay with any of um, but its fookin scary:eek:
175mph on Autobahn but then my Turbos Blew! Then again my EBC became Disconnected and i hit 1.5bar of boost :shock::shock::shock:
Still had decent amount left so id deffo say 180! Hope you find a nice long track for your top speed run :)
Where do you lot find places to get that speed?
Back roads lol!!!:rofl:
I've had mine at 187mph and still pulling.......but ended catastrophically when i seen the boys in blue!
Could have kept going though!
You need to use a better speedo source i recon the stock is well out after 100 or so.
Sat Nav Bud ;)
if you see the boys in blue at that speed what where they in because they coulnt keep up with me and set up road block only doing 165
*sniff* * sniff* does anyone else smell that ? :xxx:
I believe the copper was doing 40mph.
He seen me flying up in his mirror so the crafty git used his hand brake (no brake lights) to slow down. I seen him in time and well, wrecked my engine!:hurl::hurl:
I've done 60mph in the slicktop.....was scary !!
......but then I was being towed on about 3ft of rope by a 4x4
Yeah I know it frickin stinks, thats the reason I don't come on here that much anymore. I've got a peg on my nose today ;)
