Retro620ti
  1. 104.9 for vpower down here, bloody ridiculous
  2. check ptu and connectors , try a good ptu
  3. hope this helps bud, hows the fueling prob going
  4. 1990-1995 Nissan 300ZX Pin 1 Ignition 1 Coil #1 2 Ignition 2 Coil #2 3 Ignition 3 Coil #3 4 AAC Valve 5 A/T Control Unit PW 6 Cooling Fan Relay (300ZX Turbo Only) 7 Tachometer 8 AIV Solenoid (90-92 300ZX) 9 Air Conditioner Relay 10 ECM Ground 11 Ignition 4 Coil #1 12 Ignition 5 Coil #2 13 Ignition 6 Coil #3 14 A/T Control Unit 15 A/T Control Unit 16 ECM Self-Shutoff Power Source 17 Data Link Connector 18 Fuel Pump Relay 19 Cooling Fan Relay 20 ECM Ground 21 Diagnostics Receive Data 22 Diagnostics Transmit Data Switch 23 Knock Sensor 24 25 Wastegate Solenoids (Turbo Only) 26 Mass Air Flow Sensor Ground 27 Mass Air Flow Sensor MAF 28 Engine Coolant Temperature Sensor 29 Right Side Heated Oxygen Sensor 30 Sensor Ground 31 Diagnostics Clock EGT 32 Malfunction Indicator Lamp 33 FICD Solenoid 34 Power Steering Oil Pressure 35 Fuel Pump Voltage Control (300ZX Turbo Only) 36 Fuel Temperature Sensor 37 --- Spare Temp Input Avail, 0-5 Volt 38 Throttle Position Sensor TPS 39 EGR Temperature Sensor 40 41 Camshaft Position Reference Signal 42 Camshaft Position Signal 43 Start Signal Cranking 44 Neutral Position Switch 45 Ignition Switch +12V 46 Air Conditioner Switch 47 Diagnostics Check Signal EGT 48 Power Source For Sensors +5V 49 Power Supply For ECM 50 ECM Ground 51 Camshaft Position Reference Signal 52 Camshaft Position Signal 53 Vehicle Speed Sensor 54 Idle Position Switch Switch 55 Left Side Heated Oxygen Sensor 56 Throttle Sensor Output Signal 57 Power Source For Idle Position Switch 58 Power Supply Back-Up Permanent +12V 59 Power Supply For ECM 60 ECM Ground 101 Injector 1 102 EGR Control Solenoid Valve Idle 103 Injector 3 104 Fuel Pump Voltage Control 105 Injector 5 106 107 ECM Ground Power Ground 108 ECM Ground Power Ground 109 Power Supply For ECM 110 Injector 2 111 PRVR Control Solenoid Valve Injector 112 Injector 4 113 VTC Solenoid Valves 114 Injector 6 115 O2 Sensor Heater Injector 116 ECM Ground Power Ground
  5. think the oil cooler is 45psi it starts working at anyway
  6. you really need to find the overfuelling problem bud, thats gonna end in borewash
  7. for me dont mention fuel........20 quid will get me a 100 mile commute with only a few entertaining moments, did 3 laps of castle coombe at full bore and used a quarter of a tank
  8. wont be at the devon show bud, my missus has spent all pennies on the bloody hols so im skint, didnt realise you wanted a NA one , cant remember if they are imports or they did uk spec on em
  9. Will let you know bud, as you said it looks a good buy and for that price i think every owner can upgrade their oem brakes and get mintex pads
  10. soda wata with a dash of angestura (spelling) bitters
  11. roofs off above 70mph (sorry love? did you say something?) DONE THAT headbutt to the nose (harsh but works) WANTED TO DO THAT A FEW TIMES locked in the z boot JESUS DONT TEMPT ME and finally with seatbelts on door cards, pull over in layby and open door until you squeeze the life out of her! (anaconda stylee) DONE BY MISTAKE ONCE OR TWICE( PRACTICE MAKES PERFECT AND ALL)
  12. I DID say no piss takes, im sure i typed that.................
  13. cheers bud, if it drones out the missus screaming" were gonna die you prick" then thats a deffinite improvement....lol
  14. cheers greg, do they warp like oem?, good thing about the mintes xtreme is they are great value so dont mind it eating the pads. as long as they last till i have the pennies saved for a upgrade thats all i want.
  15. hey starks bud, im Zxter from kernow kruz mate ( no piss takes lads theres some good guys on the site) The quote you probably got was for a UK spec one, if its a import you have to tell them and the prices soar. If you get down to the south cornwall gimme a shout and I will bring my Z along and you can see what you are exactly buying into. shame about the 100nx as you put a lot of one offs into that.
  16. i will do a write up when i get em and do quality testing, as for the price its the same as a decent set of pads so not a great loss as im saving for a big brake upgrade
  17. hi zogg. .lol was me bud yeah that feckin bike, that r1 has me every time, im getting closer tho as im keeping with him up to *** then hes just pulling away too fast Hows your motor bud, had it diagnosed yet?
  18. my misses has gone out....................fecking heaven
  19. leave the uneducated masses stay the uneducated masses, allow the educated people to drive there Z's
  20. thanks vijay when yours has lifted the car up does your rear wheel come off the ground as well as mine is?
  21. just got mine today, happy with it
  22. Anyone heard about these http://cgi.ebay.co.uk/NISSAN-200SX-300ZX-GROOVED-BRAKE-DISCS-MINTEX-XTREME_W0QQitemZ200128526779QQihZ010QQcategoryZ23013QQrdZ1QQcmdZViewItem
  23. I will pay by paypal then , £37 plus 12 is still a good buy considering how much the last one went for on ebay.
