Retro620ti
  1. same here, entj, hi fieldmarshal zogg
  2. thing is you are trying to sort your idle with a vac leak from your clutch booster
  3. heres a usefull link http://tech.aus300zx.com/
  4. the yellow conector is the one you wanted to do
  5. yeah 1 hr should do it look at this as well http://www.plantbonz.com/cars/photoguide/
  6. remember once youve done all this reset the ecu, let it learn whats working right
  7. just imagine a fat tired overworked underpaid vin diesel, nope im still nothing like that
  8. HICAS Diagnostic: Turbos come standard with High Capacity Actively Controlled Suspension, a fancy way to say 4 wheel steering. There's a visual diagnostic mode to check for problems in the HICAS functions. The 90-93 TTs have hydrolic HICAS running off the power steering pump, where '94+ utilizes electric actuators to handle the rear steering chores. Their codes are a little different, but the procedure is the same. It might required a few tries to make it work. Be persistant! Procedure: 1. Ignition switch 'off' manual tranny in neutral or A/T in 'P' 2. Start the engine 3. Within 10 seconds after turning the key to 'ON', start the engine, turn steering wheel from left to right 20 degrees from neutral 5 times or more times & pump the brakes 5 times. Then press the brake pedal again to enter the test mode. 4. Turning the steering wheel left or right past 20 degrees from neutral will cause the rear wheels to turn slightly (~1 degree) (1.). 5. Drive the car forward 15 feet under 9mph to enter the full diagnostic mode. 6. The HICAS dash light will flash a code indicating any problems. Long flash is first digit, short flash is 2nd digit. 7. Diagnostic mode is exited when: ignition is turned off, vehicle speed exceeds 9mph, or diagnostic has operated for 5 minutes. HICAS light codes for '90-'93: 1. HICAS solenoid R.H. 2. HICAS solenoid L.H. 3. Cut-off valve 4. Power Steering solenoid 5. Vehicle Speed sensor 6. Steering angle sensor 7. Steering Neutral positon sensor 8. A/T: Parking Brake Sensor M/T: Clutch sensor 9. A/T: Inhibitor sensor M/T: Neutral sensor HICAS light codes for '94-'99: 11. HICAS control unit 12. HICAS motor power supply not present 13. HICAS motor output not present 21. Vehicle speed signal not present 22. Steering angle sensor angle signal not present 23. Steering angle sensor neutral not present 24. Rear main sensor input not present 25. Rear sub sensor input not present 31. Parking brake sensor input not present 32. Inhibitor switch (A/T) or nuetral switch (M/T) input not present 33. Engine speed signal not present
  9. oh *****x, need that so much, gonna have to save a bit though with xmas and mot and insurance due in jan
  10. make a water protection cover for the filter and maf , i used a bucket cut in half and a semi circle cut out of the bottom so it sits over the maf connection to the pipes
  11. targa rubbers could be good but door rubbers crap, check the join between the two seals, try a bit of peanut oil on em
  12. hes great for getting women to talk to you in the summer when youre out walking him , hes a friendly dog and seems to run to women all the time, well trained.
  13. Australian terrier jack russel cross called scratcher
  14. heres ours , standard green tree with devil dog beside it
  15. really hate cruelty to animals, they dont know why its happening and havnt done anything to deserve this, when i was a kid i caught some tossers trying to drown a cat in the local pond so i dragged the main culprit into the middle and slapped him around a bit , the others ran off and i got in trouble for it, my old man was proud tho and i knew i was right
  16. Some of the things said in the heat of the moment are meant but you just never have the cahoonies to face them when things are going ok, sit down calmly think about what happened and decide if what was said was meant and if it was try and sort the problem out on the back of the argument to make sure it doesnt happen again otherwise it will boil up again at a later date, hope it all works out for ya bud
  17. 20) Every bloke has at some stage while taking a pee flushed half way through and then raced against the flush. true
  18. new tag line..." then we will fight in the shade"
  19. say bye bye to blue ray as a technology unless there is more buy in from the public tho
  20. right just bought a 360 because of the following reasons 1, ps3 has removed backwards compatability on the 40gb ps3 model meaning it wont play ps2 games at all 2, even though the ps3 is more advanced the gpu is inferior to the 360 the design of the ps3 cell system means the fill rate and draw rate of the 360 is better 3, developers of games are struggling with the ps3 architecture and getting decent results from it are labour intensive meaning the 360 will see games way before the ps3 4 yeah gt5 is gonna be awesome, if your willing to wait a year and a half past release date for a awesome game then fine buy a ps3.
  21. would be a better test against two new oil fills, say one with rp oil and one with a decent synth
  22. oh *****x to it, i was gonna be all diplomatic but feck it, this is frickin ridiculous, surely it should be about getting them well and all time should be spent on this not the bed moving.
  23. 5ft 8 and the main problem is no steering wheel adjustment, not a problem in the car and driving, just climbing out of the car
