Homebrew
Everything posted by Homebrew
  1. Worth every peny IMO
  2. Short out the connector on the power steering pot will disable the hicas, a red warning light will come on dash just unplug the bulb.
  3. Is there a write up on how to remove these?
  4. I used to get this. The problem is the rubber seal between the center panel and the bumper, it goes dry and cant make a good seal. Either get a new one or do as I did and put some liquid gasket between them for a tempary fix.
  5. Thanks fraser, i'll print it off and run through the diag.
  6. Cheerz Chewie for replying, yes it does seem to have a mind of its own! Anyone else have an idea why I don't get heat from my demister?
  7. I am not getting any heat through the demister or through the central vents, I only get heat to the footwell. Any ideas why its not coming through the demister and central vents? I have recently done a major cam belt service and replaced coolant. I'm sure I got heat to come out of the demister before. Cheers.
  8. Try cleaning the temp sensor connector (yellow connector) on upper rad pipe.
  9. I just had 2 rear Toyo Proxis T1-S fitted and i'm amazed at how much the car grips compared to my old falcans. Don't know if the T1-R is any better though.
  10. Anyone got these bovs? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1&item=7963734385&category=33742 They can also be used as recircs, just wondering if they are any good. £97 delivered.
  11. I have had the same problem as you Tizer, usually after I have washed the car. The water gets in where the center panel meets the bumper (the rubber seal perishes over time) and drips on the filter. I'm going to fit a small polythene sheet under the affected area to direct the water drops away from the filter.
  12. Take the MAF and filter off, dry them out using a hair dryer, clean connetor, put all back on.
  13. Not sure if this would help but did you bleed the abs unit?
  14. How about get your hammer and chisel out hack the turbos off, that should do the trick.
  15. I tested the stopping distance from 60mph to zero on the zed using my Gtech pro and got 120ft. I tested my dads Focus its only 1 year old and got 130ft same day same road. I use EBC green stuff for the pads on the Z everything else is stanard brakes. I would say the brakes are quite good on the zed when they are in good working order. One thing that lets them down is the responsiveness, you have to press really hard on the zed brakes to get it to stop well, on the Focus you only have to tap the brakes and your face is on the wind screen!
  16. These Toyota owners are so sensitive, I wonder why lol.
  17. I'm going to be replacing my antifreeze/coolant next week, which is the best for the zed? I heard Nissan made one specially for the zed, any suggestions? Cheers.
  18. I have a pair a j spec tagra blinds i'll bring along with me if anyone wants to buy them, £20.
  19. Got my roof off for the first time this year today! :)
  20. Me and the zed have been together for 2 years next Tuesday and what a great two years it has been! She has been very reliable and lots of fun :) So I thought I would buy her a few gifts to keep her happy for another couple of years:- 60,000 MileTiming Belt Kit. NGK Spark Plugs Stillen Lower Radiator Hose Goodridge 300ZX Stainless Steel Brakelines Oh, I was sent a nismo thermostat by mistake, are they recomended for the 300? I may put it up for sale as a standard one came with the belt kit. :)
  21. Homebrew replied to a post in a topic in General Discussions - Non 300ZX
    Van daily for work, 300 for weekend play :)
  22. Hi Nick, sorry to hear of your zed problems. If you want a lift over to the Ironbridge meet your welcome to come with me in my zed, i'm only 3 doors away from you :)
  23. Here is a guy in the UK doing a single turbo convertion http://www.japmetal.com/forum/yabb/YaBB.cgi?board=Proj1;action=display;num=1106172244 Master power GT45 turbo. The lag must be horrendous.
  24. Hi Legrath. Those clear lenses make a huge differance to the car, much better than the orange. I'm tempted to give it a go, is there anything that can go wrong with the DIY approach? I don't want to get half way doing it to find I have broken somthing only to have to buy a new set of lights. Cheerz.
