What next????
Done so far....
Mongoose Exhaust
Apexi Induction
Chip
Boost Controller
Lightweight Pulley?
Suspension?
Brakes (Porterfields R4-S already)
Injectors?
De-cat?
Ground Kit?
Short shifter?
Fluffy dice????
Power wise decat and down pipes, and guess what.................... in stock :D
Turbo Timer, De-Cat, Remove AIV valves. Colder plugs dependant on what boost u run.
Me too AIV valves????
How's a body kit make it faster surely it makes it slower more weight=slower 0-60?
AIV's are the annoying valves in the wing area that gurgle. If you decat you might as well remove them which means less vacuum hoses to leak and slightly less weight, but they dont weigh much.
Is there a write up on how to remove these?
Yes .. but the link isn't working ... sure someone will find another one though ...
I was always led to beleive that you should make sure you can stop, before you can go faster!! ;)
So my advise would be to make sure your brakes are up to the job, before you go for power mods. Even if it's just subtle mods, at least give your brakes a once over.
Oh! And how about a strut brace, it'll stiffen up the front end (or back aswell, if you want), making it handle and feel a lot better.
Im with Dave on this!!
BRAKES
:D
Always thought you have to use both front and rear strut braces otherwise it gets unbalanced.....also i need to find one's that fit properly????
Well I've just received a set (front up, and rear up), so I'll let you know when I get around to fitting them, hopefully before next weekend ;)
