JaiKai - Full rebuild & Respray
So its finally happening after been off the road for well over a year the zed is on Target for its refurbishment.
Last year I started with doing all the underbody suspension stuff to make the ride more stable and after that
I decided I wanted to do a full strip down to the bare shell and start from scratch to create a show quality z32.
After much bad luck and many thousands of pounds wasted on rotted zeds i'm cracking on with the original plan.
So as a quick update i'll post some older picks followed over the next few weeks by an overall progress report.
Starting off with how she was when I first purchased her 3 years ago until the state she is now then showing the
strip down and all the bad luck I've had.
So here she is as I bought her :
  • Replies 834
  • Views 96.7k
when i rebuild mine every one told me not to split them, cant remember the reason for this.
you are 100% right Dan...splitting these calipers is asking for trouble and theres no need anyway for a seal rebuild.Ive never ever known these split calipers to leak from the mating surfaces of the 2 halfs and the internal seal never fails too. Nice feeling having new piston seals as the brakes do actually work much much better for it:yes:
Nice job, going to be doing something like this myself... But I won't be splitting the calipers!!!:biggrin:
Back to the callipers and first coat of paint on the front its on.
The paint is fairly thin so i'm guessing a few coats then a top clear coat.
You only need enough of the color coat to get an even colour.
Use multiple layers of clear coat on top to give you sufficient protection.
If you could get them done in 2K clear rather than regular single pack rattle can lacquer then it will last longer
Instead of brushing them in a sideways motion, you could always 'stipple' them with the brush. You won't get brush strokes then.
TBH, getting the powdercoated isn't expensive if you wanted to go that route.
