Retro620ti
  1. so you would fit breather filters at one end and a vac pump sucking though the other..anyone know what pressure the crankcase gets up to as the vac pump would need to be higher to avoid through blow on the filters
  2. you know what im thinking, feck this recirc sys lets run all the crank vents to one catch can and supply a load of vac to it benefits : no dirty gas in the intake, full crank gas cleaning even on boost just cant find enough vac to do it properly was thinking of trying to T into the inlet pipes working out the flow with the diameter of pipe as the tubs should create enough vac but worried about passing the old gasses through into the tubs and loss in power and worried about the old gasses getting compressed causing det.....any ideas
  3. yeah you need a higher vac at the rear end
  4. What about this sort of set up andy..reckon it would provide enough vacuum?
  5. yeah i was trying to work out what happens when the valves fail , obviously the springs stick or fail and the valve sticks open all the time and allows gasses at idle through when it shouldnt. The only way I can see to get a catch can to work is to keep the pcv valves with a catch can before the pcv valve solely for the purpose of cleaner air through the inlet....another solution to the pcv valve thing is to refit new ones remote from the plenum to make them easier to get at.
  6. class...up to episode 5 it was great , started to slide after that
  7. andy I have been thinking on this and need some info if you have it PCV valve works using vacuum, boost, spring pressure and crank pressure. When at idle i take it the vacumm and crank pressure isnt high enough to crack the spring break and the valve stays shut.? When on boost the boost manifold pressure along with the spring pressure is high enough to keep the pcv valve shut ( higher than crank pressure).? When at higher than idle rpm and on vacuum the crank pressure and vacuum is enough to crack the spring and let crank gasses into the inlet.? Is the problem that removing the pcv valve you lose the vacuum which sucks the crank gasses out?
  8. is there anyway to check the injector across its connections
  9. swap a injector into no 4 and see if it still does it to rule out the injector bud
  10. yeah i cant believe cate garraway takes it up the backdoor
  11. my main worry is that i think that the pcv system works via the valves with manifold pressure as well to keep them closed and moving them to a catch can means they might open more..thats what im not sure on.
  12. I have been thinking about this myself and was wondering about a catch can set up still using pcv valves with the catch cans after the pcv valves and the openings plugged on the plenum but im not sure on it myself hopefully andy will be along soon to inform us
  13. I am currently trying to contact Mac with a view to sourcing and supplying clothing with my own Z logo on it, it was just going to be a thing I did for myself but I wondered if anyone on here would be interested in such a thing, I am thinking a jacket sweatshirts and poloshirts, if mac and the board ok this I will post up my design to see if there is enough interest...the design caters for TT and NA vehicles.
  14. isnt there a relocation of the det sensor mod somewhere which makes it easier to get to if it goes kaput
  15. lovin it bud...surely that is deserving of a free years membership...thinking about it though that means we got to put up with bantam for another year ...scratch the free year idea...still fookin class mate...who is the soundtrack...might download it
  16. jdm's are different , sure when i got my clear indicators the 180degree bayonets supplied with em didnt fit
  17. give him a muzzle and a bone for a present
  18. was in the RN and used to love it when it got really rough...never ever got seasick
  19. wow happy birthday bud geez your gettin old
  20. the question needs to be turned on its head how many gallons to the mile
  21. add a grand to that and get yourself a 2.8 a4 quattro
  22. ahh just read the api site so am not surprised they dont offer a high spec oil pump as they are suppliers not tuners..my mistake just out of interest mate how much did the replacement unit set you back
  23. slightly surprised they dont supply a high spec oil pump though
