DBnathan
Everything posted by DBnathan
  1. excellent many thanks scratch has been annoying me
  2. what would be the best way to remove light scratches and marks on the clear cover while i have it off the cluster cheers
  3. there used to be a good car elec placew behind the vw garage in hedgend just off the roundabout coming from westend towards botley hope that helps
  4. have you tried starting it and testing the charging volts turn every thing on when running should still be charging over 12.5v with all on if it is alt is good
  5. not the same make of car i know but did an engine swap etc in an old mitsubishi i had ran the same as you have described would start idle low miss and run like sh*t eventualy found it to be an air leak on the intake manifold have you checked yours to see if any air leaks, wont be easy to hear on the zed engine so try a weak solution of washing up liquid and water sprayed around the intake gaskets and pipeing hope this might help you out a bit
  6. my prop is made up from tt front prop and na rear prop so was bound to have a problem somewhere ps groove you have pm other site thanks
  7. i cant see how different profile pads would make any difference to make full use of the pad you would have to grind or machine the calipers, and have different brackets, before you ask the leading and lower edges of the caliper are only about 2mm from the discs outer diameter, and i certainly wouldnt recommend grinding or machines calpiers for the fact it would weaken the overall strength, you could either stick with standered pads knowing they will wear like that and upgrading to decent calipers at a later date/ or downgrading discs to standered most expensive new calipers and disc specific designed to fit the zed correctly
  8. hi groover has new centre bearing and gearbox mount so i know it is not them
  9. i brought my zed with brake upgrade has 340mm discs tt calipers and the same looking bracket i too found that my pad have the over hang due to the fact you cant mount the caliper any closer to the disc, IMO it is poorly designed and soon as funds allow am upgrading to brembos, saying that even with the overhang brakes feel better than standerd but tend to fade when in and out of roundabouts and turns near me
  10. i just fitted a tt auto box in my car found the prop was larger splined had to sorce another prop you will need to get it balanced though have had to take mine back off to get it balanced as felt like being sat in a massage chair lol all the best
  11. good luck evryone whos been had
  12. thanks all my z is N/A at the min want to get a TT manual conversion done in the near future and while doing it have it tuned/rebuilt for more horses so by the sounds of it Andy duff and Jimmer and other bits and pieces poss d2 thanks all for recommendations gonna make a few calls only other thing i saw somewhere you can buy complete front clips anyone know where in the uk i could get a decent one
  13. thanks all you have been of great help will have a look at there sites
  14. ive heard Andy duff is good where is he based would be interested in giving him a call thanks any details on D2 please
  15. goto the dvla office with all your paper work mot,insurance, they will tell you what form to use and can replace the form and tax the car while you wait i did it on mine this year
  16. fiber glass can warp when over heated during curing any number of things can cause it you can trim it down to fit if only the lower edge is out of shape to the dash
  17. i after a decent zed mechanic garage, for doing repair servicing and mods to my zed, have recently become a member and now want to find a good place that knows what they are doing am willing to travel for the right price, have only had my zed on the road 2 weeks now and had been off the road since 2006 thanks
  18. i have the Original Titanium as well i been told the originals are rare too not sure though
  19. Hi all Only recently got my Z its a N/A 2+2 1990 in black had some mods to it already, needs a couple of things done to get on road like tyres only the 2 other than that just sort stereo wiring as all opposite +/- to the speakers cant wait to have it done whoop whoop Nate
  20. just emailed you thanks would be great Nate
  21. hi funkyboogaloo just emailed you im in newport also am after you input if poss thanks
