DBnathan
Everything posted by DBnathan
  1. get a magnet and go over the car it will stick well to the non filled areas and not as well to filled will at least give you an idea where filler is on the car
  2. also try Sky insurance
  3. my cars off the road till i can get another TT autobox keeping it auto for the misses so when i get the spare money will get myself a TT manual
  4. check the line between the fuel rails under the throttle cables and also retighten all of the clamps first if that dont solve it then could be a O ring pinched when injectors fitted
  5. will have to meet up oneday when my zed is better have a welsh meet
  6. i blew one gearbox in novemeber then another few months later so looking for another box now AGAIN lol where in St Mellons are you not seen a white zed around and back and forth from there to friends all the time
  7. black zed in duffryn is mine blown gearbox at the min though
  8. did this zed ever have an owner claim it then
  9. pull your head unit and unplug it try again with fuse is possible that the live for the light dimmer has been connected by mistake not the amp feed, so instead of powering amp is over powering the light fuse and blowing it seen it done before in a toyota lucida hope this helps
  10. sounds good theres also j1ocky in swansea
  11. Nathan -newport-wales
  12. could not possibly be the same as yours but lift the rear end and spin the prop mine had some loose weld inside the front prop half causing an annoying clinking noise also check the centre bearing if two piece prop as can cause vibrations when knackered hope this is of a bit of help for you will be interesting to know what the outcome is, all the best in getting it sorted
  13. i'll be there lol see you then
  14. was just on ebay at the time so posted some links to them incase it help no worries all the best
  15. have seen ptu's relocated to the passanger side near the fuse box and headlight hope this helps
  16. have you had a look at the tyre tread is possible that the tyre has gone out of shape would cause uneven wear over the tyre
  17. http://cgi.ebay.co.uk/NISSAN-300ZX-Z32-3-0-TT-FAST-ROAD-SPORTS-CLUTCH-KIT_W0QQitemZ260458221407QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item3ca4850f5f
  18. try this place might not be of help to you but worth an ask they rebuilt my neighbours clutch they do brakes and all sorts Brake Reline Services‎Unit, C2 W Point Industrial Estate, Penarth Rd, Cardiff, South Glamorgan CF11 8JQ, United Kingdom 029 2070 2900‎
  19. try the coloumn and hub from a TT that had all the extras hicas/cruise etc would have thought this would have more connections on it
  20. sorry but why not put a warning post telling people not to buy from him all i see is posts saying items not recived or problems getting correct items from this seller no offence meant, but does seem to cause a lot of grief for people
  21. try and pull the front out befor removing any of the structure that way should return mos to its original postition then cut out the damage will save a lot of swearing in the long run
  22. why do you want aircon in the uk anyway just remove the tops or open the windows and listen to the exhaust rumble and comments as you pass pedestrians never hot enough in this country for it, added bonus less weight and things to go wrong lol
  23. take the number to a locksmith they should be able to make a new key if in their programmes on there computer might need to take documents to prove you own the car but not sure hopefully will help
  24. you should be fine fitting a new clutch and pressure plate straight on they are balanced anyway and has been said the crank and flywheel already have, if any vibration which i doubt would be minimal and not noticed when driving
  25. check around the fuel lines and around the fuel pipe under the throttle linkage tighten all of them up
