DBnathan
Everything posted by DBnathan
  1. are you getting any oil spots or water where the car is parked i wouldnt keep running it until you find and sort that leak could be a water pipe to the turbo that is leaking on to the exhaust or oil finding its way down and out of somewhere best to sort that before any other running issues mate
  2. imports are 100% bronze blue is clearer but does not look right with the rest bronze mine has had a blue screen uk one fitted at sometime in its life
  3. picture would help mate
  4. T top seals different size, tailgate different size as with quater panels and windows fuel tank is infront of the axle on SWB on LWB in the rear exhausts different length hope this helps
  5. lol glad you found this out can make sure i dont connect mine wrong when refitting my plenum
  6. bet your grinning like a cheshire cat jeff with all these guesses
  7. too right groover come on all the watchers add your 2p's worth
  8. i think jeff's gonna wait till he has 10 pages of answers at this rate
  9. lol forgot was NA last one i done was tt still thinking tt engine connections well spotted
  10. O2 sensor connected to idle control
  11. youve been over the connections so cant be as simple as mixed O2 one up with boost soloniod connector or egr soloniod
  12. as in beverly hills cop Bananas in the tail pipe lol
  13. earth wire left of the plenum or fuel rail
  14. wouldnt be surprised Andy
  15. wet ECU working enough to run but like rubbish
  16. why not just doublesided tape it back on would be cheaper
  17. cant edit my post so all the best and hope you get it sorted good luck Suzie
  18. just a thought check the footwell on the passanger side see if it is wet just a thought as ecuand everything is down there
  19. dont bother with that size and cfm my mate has one and his DA cuts out after about 30secs as doesnt provide enough air in the tank, only just has enough to to undo two wheels worth of nuts before compressor has to kick in and at that airgun is almost at a slow speed
  20. have you taken off the coloum surround and checked for a feed to the starter if there is a live to the starter there then your imobiliser could be the problem, most alarm imobilisers are wired in after the ignition switch hope you get it sorted asap mate
  21. what about a main fuse have you checked the ones in the engine bay and the ones in the drivers footwell
  22. you can do but is awkward to do i have taken mine off recently and also removed the plenum to polish it while it is off is easier to clean the injector connections check rocker covers for leaks etc
  23. will still pass mot just removing helps get rid off the extra stuff nissan added and cleans things up abit also removing EGR makes for easier plenum removal
  24. it is possible to have flattened the end of the bush a little causing the problem if the bush is all the way in just use a small file on the lip and try the alignment tool every so often this way you only file the edge and not the internal part of the bush you wont have any problems with play then on the shaft
  25. try the pipe between the front fuel rails
