Spin Doctor
  1. any one in the norwich area around the feb 8 or 9th pos better for the 9th in day. sunday for me if meet up for a meet if its not snowing that is. cas SY - GT from Cheshire,,,,,,,, is comming down norwich taverham area for somthing ill be about aswell just thoght if anyone else is about. MAC Ds could be an idea.
  2. although i and some other may be in the minoraty but just type into youtube aventador in london revs and see. worth a watch if nothing else.
  3. got 10 on mine with 275 and dont stick out at all , but close enough so 10.5 i recon
  4. oh come on , you woulnt use it all the time at a low level setting, but like someone said if you are going to give it the beans nice to know you havnt got to keep looking at the rev counter to keep her below the 6k mark for peace of mind say. and yes the novalty will were out until your in the middle of town sitting next to a aventador giving it the large. sorry in my book its as necssary as giving it large up the road. and if your driving an na auto then i guess you love the looks of the car more. but when a child has a toy dose he not play.? and if you got it then flaunt it.
  5. Right ive been looking at the write up on these but still have a question. here is what i found: This is Bee*R’s popular two-stage ignition cutting rev-limiter. It is used to prevent damage arising from over-revving your engine. Part of the reason for its popularity is the large flames and loud bangs it produces from the exhaust when active! The way in which it works differs from the factory rev limiter in that it is an ignition cut, as opposed to a fuel cut. The reason for this is because if an engine (particularly turbocharged) regularly hits a fuel-cut rev limit (such as in high performance driving, or particularly drifting) engine damage can arise due to the lean condition produced when the original ECU shuts off the fuel pump. The BEE*R rev-limiter allows fuel to pass into the engine still, limiting engine speed by disabling the ignition signal. The Bee*R rev limiter is fully adjustable in 500rpm increments, for safety reasons allowing only a lower rev-limit to be configured than standard. If you have spent a lot of money tuning your engine, or are running at high RPM’s for extended periods of time, it could be recommended to run a lower rev-limit to prolong engine life. Both Formula 1 and JGTC cars use ignition cutting rev limiters, so it is a fully race proven concept. The Bee*R can also be used as a “two stage rev limiter”, as an aid for launching your car. The Bee*R is configurable for two different rev-limits. A lower rev limit can be activated by a switch, the handbrake switch often being used. This configurable lower limit, can be set to the optimum RPM to launch your particular car from in 500rpm increments. When the handbrake is released, the usual rev limit comes into action, allowing quick launches, and full performance down the strip. The Bee*R rev-limiter has another final neat feature. The gain control knob allows you to adjust the frequency of the ignition cut. This in turn changes the frequency and sound of the flames and bangs from your exhaust! Available for use with all rotary, 4 and 6 cylinder engines. (No V8 application) Right and heres my question?: right so you cut the ignition signal to stop the car from reving. got that , the car is still dumping unburnt fuel into your exhaust ,right. got that. but were does the bang come from when the unit times out pending on your ajustment then the ignition comes back on then the engine fires and were most of the unburnt fuel in the exhaust right? and if this is the case wont the bang dend a shock wave back into the cylinder or is this not possible cas the valves are shut. and the cars ecu dosnt get or rather fell and regester the what would norm be considered knock/ denotation? if you get what im saying. i hope im making sence. ???
  6. you should have a look at the front side light on an mot thats even funnyer and thats why i can have mine were they are? down on the bottom lip of the spoiler. all we need now is to get rid of front facing nunber plates. that said it looks good mate. not for me but it still looks good.
  7. let my buy them of you then ill let you know. - - - Updated - - - need pic i would have thought
  8. anyone on here got on. i like that its ajustable so you can set ur revs for say 4.5 5 thou so u dont damage the block dump aload of unspent fuel in exhaust and bang. cool. i want one but itll have to wait for the summer.
  9. when you watch the youtube you see the cars reving up and giving the pop pop bang flame thing. now how how do they do that and are they damaging the engine, asuming its warmed up and the cars not reving its nuts off.
  10. frist thing to do is pick up the phone and explain to the bloke of whom you boght it and kindly aske if that has ever happened to him? and say i just need to know so as i can attain weather its an intermitant fault for a start. then may i ask how have you checked weather you have fuel checked the clyinders and ptu.secondly diconect the battery for an hour chrge it up on a trikle over night and try again. it cant be the starter otherwise the car wont turn over it would just click.
  11. well done ,now thats another post as well for me, cheers
  12. D a mate you dont want to get a body shot blast , chassis yes body no. and for acid dip good luck finding someone with o swimming pool full of acid , it ant going to happen in the real world we mere mottols live in . the plating process after on that scale is hudge. and as for removing all the rubber bonding ect between the panels. nice idea though. its a da and a few days work to get a car back down to were you want it. and if you do have rust you woulnt want to treat with acid anyway yourll want to cut out and replace. good luck. if your going for that sort of repair to the shell then i can point you into the right direction with some contacts/ mates who are still working on the custom car seen but be warned to speak to your bank manager over dinner before. lol.
  13. whilst the car is in the air having the whole rear end converted from tt to a na rear i thought to myself might be a good time to fit braided fuel hose right throught the car cas my last mot said it might well soon need replacing.so also might be cheaper? so were should i best get it from ? and i think also its 8 mm i think thou i dont know for sure. and them however much am i going to need. dont want loads of links. cheers. sorry Mark. just an idea.
  14. more info ,on these anyone else use these? they have a good right up and the loads cheaper than the OEM ones. everyones a winner.: Clevite Main Bearing Set. Clevite® engine bearings have an extensive, long-standing history with racing. Our Clevite product has been winning NASCAR®-sanctioned races since 1948, and is the exclusive bearing of NASCAR Performance. We offer the most extensive line of performance engine bearings in the market. Our range of performance engine bearings is designed to provide winning results even in the most demanding applications. Our involvement in INDY, NASCAR, ARCA, NHRA and IHRA racing as well as other forms of motorsports have proven Clevite to be the leaders in engine bearing technology both on the track and off. Since our development of the first precision insert-type bearing in 1929, Clevite engine bearings have set the pace for engineering quality. Clevite engine bearings are built above industry standards for strength and durability. The majority of Clevite performance engine bearings utilize a superior TriMetal™ design first developed by Clevite 50 years ago and perfected over time. This design incorporates the strength of a copper-lead alloy layer on a precision steel back and finally, a precision electroplated white metal "babbitt" surface layer. TriMetal is an ideal design, producing a degree of conformability, embedability, slipperiness and fatigue resistance, not found in many original equipment and competitive bi-metal bearings. [selecting Performance Bearings] All Clevite engine bearings manufactured by us are color coded for quick and positive identification of undersizes. The possibility of confusion or errors in installation is virtually eliminated by checking the color code on the side of each bearing. The exclusive Clevite® TriArmor™ engine bearings feature the industry's only engine moly/graphite treatment. This sophisticated blend, in a low friction PTFE polymer base, offers extraordinary protection and lubricity. Enhanced wear characteristics increase bearing life in race engines and high performance street engines. [TriArmor™ Link] Now, high performance engine builders can enjoy the strength and durability of the legendary Clevite® TriMetal™ bearing construction coupled with the latest in coating technology - right out of the box. It's no wonder that Clevite is used more often than any other bearings in cars worldwide and in most race cars. In addition, Clevite has been in most winning engines at Indianapolis and NASCAR. And that's why, year after year, quality engines everywhere turn on Clevite bearings
  15. I think im getting these to be fitted; Clevite 77 TriMetal Crankshaft Main Bearings 300ZX Z32 Clevite 77® TriMetal engine bearings have been the industry standard since the first patent on the cast, copper, lead composition decades ago. The success and notoriety Clevite 77 has earned on the track proves the commitment to excellence maintained by all who contribute to the Clevite 77 brand. This track success provides Clevite 77 the ultimate proving ground for technologies that yield results in all passenger car and light vehicle applications.Engineering quality engine bearings involves a number of interdependent factors. These points are just a few of the advantages Clevite 77′s TriMetal engine bearings: Seizure Resistance – Clevite 77 TriMetal bearings have as much as 40% better seizure resistance than competitors’ engine bearings. Load Capacity – Clevite 77 TriMetal bearings can withstand over 60% higher loads for extended periods compared to competitor bearings. Embedability & Conformability – The overlay on a TriMetal bearing offers a superior surface for forgi-veness, offering additional protection that can be extremely beneficial in an engine that is poorly maintained. Durability – Clevite 77 TriMetal bearings not only exceed light vehicle OE durability requirements of 150,000 miles, they also exceed heavy vehicle OE durability requirements of 300,000 miles. Even all tri-metal engine bearings are not the same. If you want the highest quality, strongest, and original TriMetal bearings, ask for Clevite 77 Engine Bearings Application: 1990-1996 Nissan 300zx NA + TT VG30DE + VG30DETT
  16. pics then. i have the same fmic what other mods you got done before going to the Noz?
  17. hope mine dont start making a bloody noise. cas i go fothing nuts. lets hope its something else im sure, have you checked ur alternater mate. or is it deffo comming from that area.
  18. can you emagine some kno? mucking about when your driving and push the button and cut u out ,that wouldnt be clever , i should emagine it wont ,if your in gear or cant unless the unit gets a signal to say the cars in netral; i would like to think/.
  19. i like the rear lights and only cas they look whiter than norm even the top ones . woulnt mind that motor in mine when she blows.
