JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 132.2k
  • And they have arrived !
A little more work on the zed again tonight,
Had to get the exhaust and down pipes off so that i could inspect the turbos.
Took me a quick 30 min to drop the exhaust but the down pipes took some more time as they were wrapped in fiber heat wrap which
is simply the devils stuff and should be messed with.
After all that was off it took an hour to remove 4 bolts and 4 nuts from the down pipes to get them off.
4 hours ago, JaiKai said:
There is a tiny bit of play with back and forth motion on the shaft but not side to side and there is no marks on the inner casing to suggest the spindle touched the casing.
You certainly don't have much luck do you?! Persistence is all it takes. Keep at it you'll get there in the end!
Great build bro. Looks like you’ve run into some unlucky issues but you’ve persisted through and your car is looking really good especially in that colour.
keep it up and I hope to see the car in person in the coming years when I can attend some meets and shows in my z32.
On 03/09/2023 at 18:04, JaiKai said:
Less than an hour or so later all the extras on the engine was stripped off too.
It seems you may need some new turbos? I have 2 sets of brand new Garret CHRAs for sale from czp as i bought them and got my hands on some other turbos for cheap, so don't need these
999 on ebay for a set or 900 in cash/ bank transfer. They're 1200 usd plus shipping & import duty usually.
Can you post the CZP link to the CHRA's you are selling?
https://conceptzperformance.com/nissan-infiniti-garrett-stock-replacement-new-nissan-oem-chra-center-housing-rotating-assembly-twin-turbo-tt-nissan-300zx-z32-431876-5070_p_2409.php
These ones
I have 4 for sale, so 2 sets to suit 2 cars. Can provide receipts from czp that are only a week old.
  • 1 month later...
  • 1 year later...
Cant believe its been so long since i dont an update here.
What i can say is my zed done more miles today that it has even done in the last 7 years.
Pushed it it long term home, loaded onto a tilting flatbed and moved to my own garage in Irvine.
Plan now to collect the engine next week and work on getting it fitted soon as my holiday break is over.
