taff
Everything posted by taff
  1. As I’ve sold my zed now got a few spares in the shed need rid will take £100 for the lot plus post don’t really want the hassle of splitting and posting separate so it’s job lot only . 6 coil packs brought as spares but never used 5 genuine hks stickers from japan 2 blitz genuine stickers from japan 4 poly exhaust hangers Hks and greddy oil filter for z32 Evc think 4 boost soidnoid Personal horn push 3 rear hub bushes Selection of spigot rings Wing mirror folding X4 whiteline subframe pineapples Lwb petrol flap Hks rad cap 3 plastic fog covers 2 side repeaters no gaskets Hks water temp t peiece Rear blind catch [ATTACH=CONFIG]112943[/ATTACH][ATTACH=CONFIG]112943[/ATTACH]
  2. 1991 slicktop project for sale 90% complete all parts to finish needs paint would suit someone with body shop experience.Ive put 7 k into this car in parts alone pm me for more details too much to list on here .
  3. Grey zed with blacked out rear lights
  4. Hi is that your grey swb zed parked on Westfields estate off Ipswich on Sunday.
  5. Hi guys are rear arch repair panels avalible for swb if so makes them cheers .
  6. I thought EH7 was pearlglow yellow not Sahara gold .
  7. Someone mentioned fitting Audi s8 discs Audi and Nissan use different pcd don't see how this is possible .
  8. Hi guys can anyone send me a link to some new rear bleed nipples there longer than the front 45mm long .Looked on eBay with no luck thanks .
  9. Seems crazy I can understand selling but not buying .
  10. Hi why can't registered users reply to for sale post anymore there's no reply box anymore why has this been deleted thanks .
  11. Hi does anyone know if the bolt on flange on propshaft just past the centre bearing will interchange between na/ and TT just wondered if the splines were a different size .I need to change bolt pattern to na on front section of propshaft to match up with a swb na rear section .This is on a TT manual slicktop with na diff and subframe beginning to think should have gone 1 piece prop now .thanks
  12. Ok cheers mate will check tommorow after re-gas thanks.
  13. Hi guys my daily Audi A4 tdi keeps loosing AC gas after around 2-3 months .It had a new compressor /revived dryer/and condenser rad just over 2 years ago .Im going to get it regased tommorow just wondered if any one had used stop leak .it has been leak tested with dye but they can't find s leak thanks .
  14. Hi I'm after the front section of propshaft from a na manual its for a swb but I think this section is the same for lwb .can collect Essex area thanks .
  15. Yes please stillen will be fine if you can measure the tube please .
  16. Hi has anyone got the measurement of this tube just bright some tubing which I need to cut down thanks .
  17. I have them fitted fine maybe they have redesigned them since .Also put in Driftworks rack spacers .
  18. Could always take it to Richard Rawlings for a gas monkey makeover .
  19. Hi has anyone got a SWB na propshaft thanks.
  20. Z31 /S13 200sx/S12 Silvia plus many more use different varieties of the r200 diff .
  21. I've cut the standard studs down in the past to overcome this problem only by a few mm .Ive had no problems with this method.
  22. I've removed 4 sets of subframe bushes now .I use a good quality hole cutter both sides to remove most of rubber and centre tube then hacksaw thew bush case but don't cut into subframe.Then chisel bush in on itself folded in and hammer it out .Ive done all 4 in2 hrs .
  23. Hi mate who made the cage and what was the cost I would like one in my slicktop thanks .
  24. If someone could measure a tube the one I have is exactly 1 and half inches long just over 35mm thanks .
