Rear drop link help
Hi has anyone got any rear droplinks off the car .I need the measurement of the tube that slides inside the bolt in length as mine appears to be too short as bolt thread bottoms out thanks .
Are you sure you have 4 bushings on it, if you don't have a bushing the nut will bottom out.
If you get no help I can probably check later
Yes got all 4 bushes in and washers there super pro polly bushes .Which didn't come with washers bolt or tube ,so brought some cheap droplinks of eBay £5 each says they fit s13 200sx and 300zx .
If someone could measure a tube the one I have is exactly 1 and half inches long just over 35mm thanks .
  • 4 months later...
Hi has anyone got the measurement of this tube just bright some tubing which I need to cut down thanks .
Do you need the length of the OEM units only? as I have my rear drop links off the car currently, but there are from a Stillen anti roll bar. They will be for sale soon as I have new front and rears on the way from the US, if that's of any help?
Yes please stillen will be fine if you can measure the tube please .
