Slick Pete.
  1. Are you sure about that??:rolleyes:
  2. Dont bother about it!! i have just checked my profile and it shows 4 "friends":shock: Well F*kc me I cant stand any of them .:tongue: they are all T**ssers:xxx::xxx: and I never invited them to be "friends":x: :D:D
  3. Italso means that any 2nd hand m cyl of unknown quality can potentially be turned in to a useable/saleable item.:)
  4. Im pretty sure the larger one is the TT size. What is really interesting tho is the price!!! Nissan Mainstealer price is waaaay more If this kit works then its the bargain of the decade.
  5. They dont . And I agree they dont really count. Anyway I dont think we will see 780Z back on the forum anytime soon.:xxx:.........unless he comes back with a new name and a new ISp address:tongue: he was banned some time ago from Z Club.net:nono:
  6. ??????? What do you mean come to a conclusion and we have a winner??? the car ran an 11.15 quarter. The late Gavin Balmer ran a 10.5 in his Z32. Mark watkins still runs 10 sec quarters in RatZ 780Z's car only has a "claimed" 550bhp(from the US) . He himself doubts the figure and reckons its more around 450 which certaily ISNT the most powerful Z in the UK. So It aint the fastest and it aint the most powerful...... game still on....:hyper:
  7. All wight removal will free up power. there are several threads about with weight comparisons etc. On big power TTs its not as significant as say weight loss on a 1.4 Corsa.
  8. Heater/blower continue to work fine. IMO. Aircon is a useless extra. Remove the fan and rad and pipes while you are there. I dont ever use aircon even in cars with it fitted. Others of course will come along and say its "essential";)
  9. Just ask Mike at MJP in the traders section. 01277 374201. thats what he does for a living.
  10. It makes no sense at all. Just buy a new one AND a new harness. Fit and forget for the next 17 years.
  11. Thats Simple...... Dont move it anywhere. Leave it where Nissan designed it to be. It works perfectly.
  12. I dont want to seem negative but looking carefullly at your repair it seems to me that you are only about 50% welded. Looking from the back particularly there is a lack of weld penetration . Looking from the front there are substantial areas where you have no weld at all. If you are replacing a hole in a plain sheet of metal you need to have 100% continuous weld at full penetration to achieve the original strength and integrity of the panel. That work would IMO fail an MOT inspection.
  13. That will be spot on.:) the point to note is at full reach it comes down to 500kg. thats Fine tho for doing the job.
  14. :shock::shock::shock: Glad you are still able to walk n talk Pete. Looks very scary.
  15. Well for starters you cant see what the new ones look like in any of the pics. Other than the fact that they are black. Doesnt really matter anyway as Rota drifts are everywhere on scruffy drift cars etc. Not even close to what you have removed:slap:
  16. Later cars had the Cast ones.
  17. Not without changing to TT discs tho.:smash:
  18. I think you will heve a problem with the starter motor. It will be too far off the NA ring gear on the NA flywheel.
  19. The usual trick is to lengthen it slightly. First step being to slip a nut in the end to see if it helps. Then lengthen rod with a few blobs of weld. i had to do this for my ACT Street N Strip cluthch to get the bite point just right!
  20. None really. They are a viscous type LSD. Same as TT only a different ratio
  21. No need for all the debate. "Search" is your friend. Its why we have a FAQ section................................ Thread Tools Search this Thread Rate Thread Display Modes Old 3rd January 2004, 09:22 #1 Paul C Registered User Paul C's Avatar Join Date: Mar 2002 Feedback Score: 0 Location: Canterbury Posts: 7,707 Lightbulb MOT emissions test on a zed (cat test) asked many times when decatting, so heres the score: any vehicle registered from 1 august 1992 has to go through the MOT BET test (Basic Emission Test), the limits are: Fast Idle CO HC Lambda between 0.97 and 1.03 Idle test CO if the vehicle does not meet these figures (decatted vehicles may well NOT) the the test proceeds on to a more specific test. if the vehicle is between 1 aug 1992 & 31 july 1995 and an exact match is found in the Emission database, then a CAT test is done using the vehicle specific details However, the Z32 is NOT in the emissions database, this means a NON-CAT TEST is carried out using the same values as pre 92 cars Non Cat Test CO HC as long as everything is running ok then even De-Catted cars should pass this! if you're lucky enough to own a 1 Aug 1995 on Zed then a default Cat test will apply, which you will prob fail if you De-Cat!
  22. I'm glad that Blue shell is being put to good use:)
