  1. Not to worry anyone but the pic of the TPS doesn't look like the one fitted to the Z32 ... Could just be a stock photo but caveat emptor ...
  2. I've been supplying the 6000K/1W LED bulbs for over two years now and only ever had two customers come back to me and say that their bulbs melted. In both those cases the cause was traced to faulty electrics which caused the LED to overheat and subsequently melt and fail. Having spoken to my supplier about this issue a number of months ago I was informed that in 90% of the cases the fault is due to irregular voltage supply to the bulb holder. Only in 10% of the cases was it due to there being a manufacturing fault. HTH Dan
  3. In very simple terms the answer to the original question is Yes. HOWEVER, .... The modulation frequency of the brakes that the ABS ECU uses is optimised for the stock brake setup. If you have larger discs and calipers then the modulation required for effective braking is different. This is why you will often find that cars with bigger brake setups tend to lock up the brakes under heavy/emergency braking. This point was made clear at ZedFest two years ago when a Dutch acquaintance of DTA-Motosport drove into the back of his fellow Dutch companion in a line of traffic. Speed was not above 20mph and an emergency braking manoevre locked up the front brakes causing him to skid into the back of the other Zed. The skidding car had 378mm APRacing discs and 8-pot calipers ... Being completely honest with you, I am unsure as to whether the ABS ECU can be altered to take into account fitment of larger brake systems. Something I need to make some enquiries about. HTH Dan
  4. Just to add to SMW1's post above, I supply the following engine "dress-up" parts: - Polished Slam Panels & Headlight Covers - Carbon Fiber Slam Panels & Headlight Covers - Polished & Engraved Throttle Cover - Carbon Fibre Throttle Cover (both stock and for Carbing Strut Brace) - Polished Intake Hard Pipes (both TT & NA) - Silicone Intake Pipes (TT only) - Polished Radiator Hard Pipes - Silicone Radiator Pipes (TT & NA) - Vacuum & Silicone Hoses/Couplers - Polished & Engraved Fuse box covers (both large & small) - Stainless Steel Braided Fuel Line Kit - Polished Radiator Brackets (KOYO/HOWE only - not stock radiator) - Anodised Panel Washers & Stainless Steel Bolts - Polished IAA Valve Feed Pipe Kit - Silicone Brake Booster Hoses - Polished & Engraved Throttle & Plenum Cover Strips ** All "polished" parts are made from mirror-polished stainless steel. Vacuum and Silicone hoses/couplers can be ordered in Red or Blue (Black and Yellow are special order only). ** Other non-engine compartment dress-up parts include: - Polished Speedo Rings - Brushed Metal Speedo Bezel - Polished & Engraved Sill Plates - Carbon Fibre B-Pillar Covers - Carbon Fibre Foglight Ducts For more information, pictures and pricing info please take a look at our website: Smithy's Place For Carbon Fiber parts please look http://www.smithys-place.co.uk/cf.php Regards, Dan
  5. The ones for the GTO were the H4 Bi-Xenon kit which retails at £125.00. For the 300 you'll need H3's which I retail at £91.00 per set plus £8.85 postage. So total cost is a smidge under £100! Installation is very straight forward. Pull out the old bulb, insert new HID bulb, secure new bulb with spring-clip, connect bulb to ballast, connect bulb to headlight wiring loom (two spade connectors) and the job's done! :) I sell the kits with ZX-specific installation instructions but you can always call me if you get stuck. Kits that I have available are H1, H3, H4 Bi-xenon, H7, HB3, HB4 - so if you have any other cars then I've got the kit for you. Only caveat is that cars produced after 2001 (like saabs, mercs, bmws, etc) will require our "Ultimate" kit as that kit doesn't interfere with the in-car lighting ECU. Just today I sold a kit to a Porsche customer (2006 Cayenne Turbo S) and the Ultimate kit is a straight fit! If anyone has any questions please feel free to contact me. Regards, Dan PS - more HID info available on http://www.smithys-place.co.uk/hids.php
  6. Hi Indian_ZX, Many thanks for the kind words and excellent pictures detailing the difference the HID's make! I'm glad to see you're happy with it. Regards, Dan
  7. Yep - very straight forward. I've got a pair of H3/6000K bulbs in stock which I can send out. Will connect straight up to the Ballast and into the wiring loom plug. Send me a pm with delivery details and how you'd like to pay (credit/debit card, paypal) and I'll get the ball rolling. Regards, Dan
  8. David (Wow300): I'm afraid that the ConZult user manual is copyrighted material belonging to Lymon and is not freely available for download or distribution. Unless a user is a registered user of the diagnostic equipment we can not send out copies. If you are using someone elses equipment and need the user manual please get in touch with the registered owner as they will have received the manual at the time of their purchase. Regards, Dan
  9. Not to be confused with "Purple Ronnie" ;-) LOL Sorry, could not resist ...
  10. There are no existing pre-moulded kits out there so you'll need to have them custom fabricated. If you do a search you'll find a few topics regarding doing the DIY. Regards, Dan
  11. Let me know what silicone hoses and/or vacuum tubing you're after and I'll sort you out. Top quality stuff. Regards, Dan
  12. True - 30~60 minutes will do the trick although this doesn't clear the self-learn parameters which can only be reset by using a ConZult, etc.
  13. Hi Si, Yes, two panel filters required - I'd recommend either K&N or A'PEXi. If going for a pop charger I can not recommend A'PEXi highly enough - superb filtration qualities and high flow rate. A'PEXi filters (both panel and cone) are dry-type filters and can be washed in water to clean. No oiling required unlike with the K&N filters. As you know, I can get both cone and panel A'PEXi filters. The cone filter costs £62.50 plus p+p and I need to check on the panel cost as I don't get asked for these very often. Regards, Dan PS - I've seen some stock air boxes with holes drilled in to them to increase the air intake ... Not too sure on the effectiveness of that though ...
  14. In true Bob-the-builder-stylee, "Yes, you can!" :) I'll put your name in the order book for a set of PFR6B-11B's and let you know when they've landed with me. All the best, Dan
  15. Hi Simon, Yes, use the NGK PFR6B-11B plug when you're upgrading your boost. If you're interested, I've got a few sets coming into stock in about a week's time - I can reserve you a set if you like. NB - the 11C plugs are primarily used for cars running stock boost and no further upgrades other than perhaps an induction kit. HTH Dan
  16. Hi Joel, First of all - no, it is not possible to convert a OBDI car to OBDII. Completely different protocols and interrogation methods. Secondly, why would you want to convert? There is no benefit to it as the car's sensors and ECU won't handle the data streams. As far as I'm aware none of the Z32's were OBDII as it wasn't a requirement in Japan (unlike in Europe). I could be wrong here but it would surprise me if it was changed. When they brought out the Z33 they switched to a new protocol that was different yet again to OBDII. HTH Dan
  17. Our ultra bright LEDs (see http://www.smithys-place.co.uk/bulbs.php - item BLB014) are colour matched to 6000K HID kits. Have plenty in stock at the moment so let me know if you want a set. Regards, Dan
  18. Glad to hear it all worked out! :) Further to your post above, from the picture you posted it appears to be a 4300K 9006 bulb (these are commonly found in US-Spec Zeds). HTH Dan
  19. On most UK Zeds with dip-dim there isn't enough power to ignite the HIDs when you're only running your side lights. The HIDs will only ignite when you turn the headlights to dip beam. Murt - the leads I provided you with are specific to UK Zeds. These use a spade and bullet connector as opposed to two spade connectors in JDM Zeds. HTH Dan
  20. Yes. The composition of oil depends on the temperature it is. I don't know enough about oil to say with 100% certainty but at a certain (high) temperature the oil will change composition and start to burn and degrade. You don't want that sloshing around the enginee. Again, I'm not sure whether 110C is high enough for that. As for any potential damage - it is possible but if the high temps were only for a short period of time the damage may be limited. I'd keep a close eye on coolant levels and also whether any bubble are appearing in the coolant. That's an early indication that the head gasket is gone. HTH Dan
  21. James, Poly bushes are not inherently stiffer than stock rubber bushes. It just appears so because they replace knackered bushes. Depending on what you need I can get Energy Suspension bushes for all the suspension parts. I would need to know which bushes you want to replace and whether you've already got uprated suspension components (like adjustable upper arms, tension rods, etc). Price is dependent on composition of the kit but I can certainly give you a quote if you let me know what you need. All the best, Dan
  22. Well, you win some, you loose some. I've had Autobahn silicone sent to me with parts (boost hoses and various couplers) and they were of very poor quality. More rubber than anything else. However, to the best of my knowledge the Autobahn silicone hoses are only 2 or 3-ply max which will go soft and squidgy over time causing all sorts of cooling problems. Try this little test: go for a spirited run in the car until it is good and hot. Open the bonnet and rev the engine. 9 time out of 10 you'll see the boost pipes (and coolant pipes) collapse in on themselves. That's not a good thing by the way ... In any case - I'm willing to accept that some silicone parts sold on ebay are decent. However, experience has taught me that the majority isn't worth the price you pay for it.
  23. :confused: It is not slander when you have 100% undeniable proof that ebay silicone (which mostly originates in China) is in fact less than 13% silicone. BTW "slandories" is not a word - slanderous is. ;)
  24. Yeah - I apologise for knocking the MR2. If it is nicely sorted with engine and suspension mods it's a very nice car to drive. Sorry
  25. Sure can! ;) I supply stainless steel top and bottom coolant hoses. Also do the full silicone hoses. The hard pipe kit is made from mirror polished stainless steel and comes with silicone couplers in either red, blue, black or yellow. The fully silicone hoses can be had in either red or blue only. Contrary to what you find on eBay our hoses are a minimum of 4-ply silicone with an additional liner to give the hoses structural integrity. Most of the eBay crap is not even silicone, despite what is advertised, and will soon perish. Prices (excl. postage): Stainless steel top & bottom coolant hoses: £140.00 Silicone top & bottom coolant hoses: £99.00 Lead times on these is approximately 10 days for the stainless steel kit and upto 28 days for the silicone kit. I also do a matching set of intake pipes in stainless or silicone. Let me know if any of the above appeals. Regards, Dan
