JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 130k
  • And they have arrived !
I’ve had the same issue mate, had to back fill the lines from the oil cooler and remote oil filter housing
Make sure you prime it without the spark plugs in, much less strain on the starter motor and effectively no load on the bearings as it’s not building any compression
On 27/03/2026 at 11:27, JaiKai said:
Looks like Z1 have screwed me over on a set of Turbos.
Ordered them 2 months ago and and i've been chasing them each week and they respond simply as we do not have an ETA.
Finally got them to tell me that parts on on back order and no longer available so after a small refund the rest was dispatched via UPS last week.
1 Week on and UPS demanded the import fees upfront which i paid only to discover that Z1 never completed the Export license information to UPS.
Now my new turbos have been returned to Z1 which i have tracking for and Z1 are ignoring all communications with me and i'm down the import fee too
as if its shipped out again guarantee it will be a new tracking number and they will demand a new payment.
I'm really at my tether with this zed and nearly had enough, everything i do to get it on the road goes wrong.
And today i have received my full refund from UPS for the original import Fees that never actually left the USA.
UPS is a shambles of a company, taken 3 months to chase and make my refund.
But i never gave up and kept hassling them to refund it.
That must be so gutting, I do wish you luck in sorting the problem.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
Got it back on the stand until i can figure out what to do.
If i need to go as far down as to take the oil pump out or inspect it then i need to strip the bottom end.
All that weight i'm not sure its safe to spin the block as is, so it will have to be done up side down in situe.
Its a brand new pump at least so thats like why its went dry or the internal grease has dried out.
I need to find a way to inject oil down to the oil pump with it on the stand.
Right so my issue is a dry oil pump as its new and likely not primped properly,
With the engine cranking over its not picking up fresh oil so i needed to somehow remove the oil tree and force oil up lines.
Only way was engine out again then remove the turbos, then the oil try to expose the line to the pump.
Didn't like the new braided oil lines so removed them and went back to the oem ones.
Which was nearly new.
The new style lines along with the oil restrictors stopped the turbo housing being clocked properly
So much better fitting after they were back.
Now await a new order from Opie oils for some smooth running in oil, then how to get this back in the zed again.
