TheVeteran
Everything posted by TheVeteran
  1. VW's are excellent cars! get some euro stylee wheels on it Janus..
  2. Heat is much needed on this bud, get your self a blow torch and warm them up. it took me 2 days before i turned to heat and they came straight out with a good smack of a hammer. Worst job i have ever come across but some peoples are far easier!!
  3. no problem what so ever bud, ill always help where i can as many have done the same for me!!
  4. yes you are correct on every note in last post buddy and yep use washers on all parts. if you require any pics just let me know james
  5. if i remember you get 4 large spacing nuts and 4 thin spacing nuts. you need to use the 4thin spacing nuts, put one on inner arm and one on outer arm. you need to use one thin nut per adjustable joint otherwise you cant lock them in. IF you use the 4 larger ones it toes out the wheels way too much! make sure also both subframe bolts are in both sides. If there not then this is where your movement is CERTAINLY.. :-)
  6. the lower large bolt goes through the arm and through the subframe. it clamps it tight. If you dont run the long bolt you get with the kit through the subframe, the bracket will move up and down..
  7. no bud, the lower one goes right though the joint and subframe... if you dont the bracket will move about.. i will put a picture up of mine in 10 minutes if you need one?
  8. I take it you have have bolted the subframe mounts on with 2 bolts per side dude?
  9. i LOVE the seats amongst everything else bud. where they from?
  10. get well soon craig! thoughts are with you buddy
  11. congratulations mate, really pleased for you!
  12. Travellers Without Authority To Stay nuff said.
  13. Are barstewards!! i hate hearing news this has happened to someone, sorry to hear the news bud, was it immobilized or anything? any CCTV around there?
  14. cheers Alan.. yer i agree.. lol
  15. Hi Chris, the post has just arrived... its my membership pack! whoop whoop! lol thanks very much! it must have been a mamoth task to work your way through all those. appreciated..
  16. Just took some pictures of the new bits ive applied to the Z over the last couple of days. Fog light ducts, sprayed the same colour as standard mid section and made my own small mounts with weather proof L.E.D side lights hidden inside. Ducts (where courtesy of CAR.MAD and are top quality.) Rear light from Big Jim, clear indicator section. Removed the orange section in front bumper indicator housing. Wrapped the rear blind holder and rear side panels.
  17. Could have been mine in pics below?
  18. Nice example that mate, good colour! Your not to far away from me and im often in Lincoln in my Z. get some more pics up:thumbup:
  19. Happy birthday bud, enjoy!
  20. is this part on all tubby Z's Jeff or just before a certian year?
  21. you got any pics of them on the Z? i reckon id like them bud, certainly suit the Golf for sure.
  22. well at least you can shave and brush your teeth while checking oil levels. bonus! Id be worried one fell off and slid into my fan.. what did you use to bond them on?
  23. mine are Et 30 offset and they are 9.5" wide at rear but ran negative camber until i had the rear arch inner lips cut out.
  24. i like the works meisters best buddy.. Your rear lights look like they have seen better days?
