Spin Doctor
  1. Dunno but it was to much before so this will fill it up nicely.before these there was a huge gap with the stretch 255 that were on there before.so the extra 20 mm width must also give some extra height in overall circumfrernce.
  2. These arived today.therll fill out the arches better.then ill get the car set up and sitting right.
  3. Nor do i.ive just got to send miles of to agreed value insurance.but wasnt sure if this needs convertng.or not.
  4. I know that if you gave jap clocks the kph to mph are different.but dose this mean i have to convert my millage reading of 091838.as well to get the correct millage.cheers
  5. Ok so why is it that you buy any product from a shop you get a recept but when you buy fuel you have to ask for a recept anless they have already asked you.
  6. I love the wide body zed and i can hand on my heart say that i also dont like the front end and as soon as ive sorted out the tubs the front is comming off and hopefully when this group buy gets back on track ill be putting on a twin z p spec front end.to hide a fmic in black. I new when i was having a deal with alan on my wide arss was i new exactly what i was getting and new all the issues that went with this car. I think you need a really ohnest seller to let you know or make sure u take somone who knows zeds inside out. And that goes to any car you buy.
  7. Just had a thought thou. Its got to be the thingy that plugs into the gearbox cas the millage isnt going up either
  8. Best and cheapest place to purchase pcv valves. Dont want nasty things that dont work..cheers.
  9. Sounds to me like you need to put back together and up your greenflag or whom ever to the max.itll be worth the extra fifty quid when you drive it anywere in the next .say mounth.if y get me
  10. Best and cheapest place to purchase pcv valves. Dont want nasty things that dont work..cheers.
  11. I ant got a clue whats going on mate.and i feel for you.i know mark d has got an air idle valve thingy and the genuine gasgets for them are only about four pound somthing from the nissan dealers.i know cas i just bought one for mine. Thatll sort your ideal out surley. Good luck bud and hope u get your baby fixed soon.
  12. i found this site surly there must be somthing to suite the 300 http://stores.ebay.co.uk/KINUGAWA-TURBO/NISSAN-/_i.html?_fsub=353351014&_sid=719450054&_trksid=p4634.c0.m322 found over 69 tubs just for the nissan
  13. Product Info:and the td06 and the tdo7 and the tdo5h from kinugawa and the t67 tdo44 Item Title Kinugawa TD05H-Garrett 60-1-8cm Turbocharger with 3" Anti Surge Cover and Billet Adjustable Actuator Item No. 301-02001-256 Application 1.8~2.5L Engine Turbo Spec - Compressor Wheel:60 mm / 76 mm (Inducer / Exducer) - Turbine Wheel:49.2 / 56 mm (Inducer / Exducer) - Turbine Housing A/R:8 cm - Turbine Inlet : T25 Flange - Turbine outlet Type : 5 Bolt - Actuator 1.0 bar (14.7 Psi) - MAX HP : 300~450 HP Includes - 1 x Turbocharger (we also could offer 0.8,1.2, 1.5 bar, please contact us if you need to change it) - 1 x Turbine Gasket Set - 1 x Oil and Water Line Kit as Pics Item Situation Brand New Bearing System Journal Bearing (KAMAK Performance Thrust Bearing Kit) Cooling System Oil and Water Cooled System Net Weight 8 kg Source Kinugawa Turbo,JAPAN International Buyer Notice Import duties, taxes and charges are not included in the item price or shipping charges. These charges are the buyer’s responsibility. We can ship item to P.O. address. Combined Shipping is available for most items and we always try our best to save freight for our customers. If you have any question or request about international shipping, import tax and declared value, please email to turboassembly@hotmail.com
  14. Genuine TRUST GReddy product from Japan, Part No. 15500214 are a bit of shopping around and have found a supplier at 242.99 , thats more like it
  15. jesus i was thing a couple hundred not this price 15500214 Item: Profec Type: new! Size: 89 x 36.5 x 22.8mm Notes: electronic boost controller (see for more info) (see Basics on our blog) (Profec Manual Download) Color OLED Display built in Boost gauge (kPa or PSI) 3 display types - Numeric, Bar Graph, & Map Graph Intuitive Control Screen and Dial control 2 preset setting, LO & HI, with 3rd timed Scramble boost setting (Lo. & Hi.) Set % - to increase boost (higer number, higher the boost over base boost level) Gain % - wastegate response adjustment Start Boost - inital boost response adjustment Warning point, warning limiter, peak-hold/Last boost compatiable with both actuator style and external wastegate style turbo systems revised compact boost solenoid Separated Display/Control Unit and Sensor Unit, for easy install Intergrated 300kPa (43.5psi) - high performance boost pressure sensor within the Sensor Unit Includes adjustable mounting bracket Part #: 15500214 Price: 525.00
  16. whats this for? Item: Speed Harness Type: Optional Size: Notes: allows PRofec to use scc switch adapter in order to switch boost levels according to speed. Part #: 15901300 Price: 12.50
  17. need to buy a ebc, will not be mucking around with it once set up, but will just turn it on and off i guess.somthing thats does what ever it needs to do so that its easy to use , dont know how much these run to, have got one on the car at the moment but the head unit went missing some time ago .so need anothe set up.
  18. So the only thing your going to gain out of using the t28 compresor wheels is.becase of the larger compresor wheel.it will hold boost for a bit longer yes.
  19. 155. Jp from somone ive used twice before and never had an issue with.they even come bubblewraped.
  20. Yes they are gt28rs jobies with a five bolt etc etc what im after is a pair of tubs that ant going to smoke.so am right in saying they need 360 thrust bearings stagered steped oil seals and since learnt possible oil lines with restritors in there. Need for a bit of extra grunt or ooomph.i will be fitting a fmic to sit behind p spec front bumper in the spring along with two half inch pipe work. I will be needing a ebc so anyrevomendation there would be handy.dont want to track her shes more of a show and shine car.but that said i do like a spirited drive lets say.and love sitting at set of lights. Im keeping the single exhaust but pending what i land up with will be replacing the exhaust from the middle to the engine as the down pipes need doing now anyways.
  21. Thats what ive now ordered.happy days. Funny though even a tyre chose took me two days of research to make my mind up.sorted now.be intresting to see howthey preform.
  22. Whitch is one of the reasons why i havnt rushed in there.and bought the first thing that came to me. Its not an easy desision to make. After all i dont want to be tacken them out again in six mounths.thats not an option for me.
