best choice of a ebc
need to buy a ebc, will not be mucking around with it once set up, but will just turn it on and off i guess.somthing thats does what ever it needs to do so that its easy to use , dont know how much these run to, have got one on the car at the moment but the head unit went missing some time ago .so need anothe set up.
IMO, GReddy Profec or Profec B Spec 2
whats this for?
Item: Speed Harness
Type: Optional
Size:
Notes: allows PRofec to use scc switch adapter in order to switch boost levels according to speed.
Part #: 15901300
Price: 12.50
jesus i was thing a couple hundred not this price
15500214
Item: Profec
Type: new!
Size: 89 x 36.5 x 22.8mm
Notes: electronic boost controller (see for more info)
(see Basics on our blog)
(Profec Manual Download)
Color OLED Display
built in Boost gauge (kPa or PSI)
3 display types - Numeric, Bar Graph, & Map Graph
Intuitive Control Screen and Dial control
2 preset setting, LO & HI, with 3rd timed Scramble boost setting
(Lo. & Hi.) Set % - to increase boost
(higer number, higher the boost over base boost level)
Gain % - wastegate response adjustment
Start Boost - inital boost response adjustment
Warning point, warning limiter, peak-hold/Last boost
compatiable with both actuator style and external wastegate style turbo systems
revised compact boost solenoid
Separated Display/Control Unit and Sensor Unit, for easy install
Intergrated 300kPa (43.5psi) - high performance boost pressure sensor within the Sensor Unit
Includes adjustable mounting bracket
Part #: 15500214
Price: 525.00
Genuine TRUST GReddy product from Japan, Part No. 15500214 are a bit of shopping around and have found a supplier at 242.99 , thats more like it
  • 5 weeks later...
Buy from a recommender dealer or someone with a proven track record, not some random guy on the interwebs.
I leave mine well alone these days, back when I used to be a pansy I turned it down to 12psi in the wet, I use my right foot as boost control now.
But, they reduce turbo lag (as I understand it) someone will probably prove me wrong :lol:
I've never understood the need to alter the boost up and down, save your money, get a mbc setup properly and leave alone.
Because MBC's suck. EBC gives much better control of spool time, spike and creep.
Yer but.surley if your cars been set up then surley you should be able to get what ? three decent settings on a mbc low med and high. Without issue. Rather than spend three hundred quid on a fancy ebc.surley better to spend that money on getting set up.whitch is the way im thinking of going.cas why would you keep mucking about with it.
Once it's been set up properly, (Noel is doing mine) the only thing I will be switching is from "A" to "B" setting
A - NORMAL (Pansie driving)
B - Ballistic - Track day, rolling road/scare myself sh15less
If they are all as complicated as my Apexi, then once set, I will be leaving well alone. As it takes someone like Noel who has a very good understanding of duty cycles etc.. to get the best from them, Oh and the most important one, LIMITING THE AMOUNT OF BOOST, to protect your engine!
Edited by bigh
Got to totaly agree with you Bigh.which is why im thinking i might not need one.an sbc that is.i had one on my other car and didnt use it.so thats pretty much what i want.norm then in the middle then full on for the summer mounths but still safe for the engine.
