craig 300
Premium Member
Everything posted by craig 300
  1. front wheels 18 by 8 1/2 J tyres 235-40-18 back wheels 18 by 9 1/2 J tyres 265-35-18 slight curb damage on the two front wheels, see photos. collection only from stoke on trent, please contact on this number, 07975940525 £350
  2. Hi yes I am interested in purchasing these. How much do you want for them ?
  3. Cheers Denis, Much appreciated. Best Regards. Craig.
  4. Left & Right inner air ducts View Advert Hi I am looking for the Left & Right hand inner air intake ducts the ones that connect the outer air intakes under the head lights to the air box part numbers 6286140P10 Left Hand 628604P10 Right Hand. Advertiser craig 300 Date 30/09/23 Price Category Parts - Wanted
  5. Hi Lee I am looking for the left and right hand inner air intake ducts the ones that connect the air box to the outer air intakes under the head lights part numbers 6286140P10 left hand 6286040P10 right hand. Craig.
  6. UK Spec Rear Wheel OEM View Advert Hi, I am looking for a UK Spec OEM Rear left hand rear wheel part number 40P10 L Advertiser craig 300 Date 26/09/23 Price Category Parts - Wanted
  7. Hi all, Has anyone replaced the cam belt idler stud bolts ? a couple of questions one is with regard to the torque settings for the stud bolts them selves the service book only seems to list the torque settings for the idler pulley retaining nuts. The other concern is how difficult are they to remove has anyone had them sear off ?
  8. Afternoon all, got a question about pcv valves just bought 2 brand new oem valves decided to check them before fitting to make sure they opened end closed properly by applying mouth pressure to either end. One of them closes fully but the other does not seem to seal fully is this normal or is a faulty part ?
  9. craig 300 posted a topic in For Sale - Parts
    For sale this HID kit was fitted to my Zed when i bought her i took it off a few years ago because of the MOT situation with regard to retro fit HIDs they worked ok when they were last fitted to the car. I have tried to insert an image which as come up as a link so not sure if it will work (not too good with PCs)
  10. 1 pair of blow off (dump valves) these were already fitted to my Z when i bought her 10 years ago. I took them off a couple of years ago and replaced them with stock recircs i hung onto them in case i changed my mind but decided to keep it stock so now they are up for sale. there is no makers name on them can post a pic if anyone is interested. I did have the original recept in my file but seem to have misplaced it i know that they came from the states.
  11. Front air filter panel, stock in good condition. Got some other parts for sale.
  12. if your talking about the black backing that sits in front of the dials then that just clips in.
  13. Hi Mate got mine from Mike at MJP the black back ground trim is part no 93094-42P10 twin turbo emblem 93094-4P02 nissan emblem 93094-40P00.
  14. wanted 2 standard recirculating valves( Z32)
  15. look awesome mate better than new !
  16. Ford graphite grey seems to match the mirror flitches pretty well.
  17. Put mine in the washer when i first bought my Z they came out as new.Not driven the car without them.
  18. I used Ford Graphite grey on mine. It is a pretty close match to the original colour that is on the mirror flitch.
  19. I used a set of those on mine. they fit perfectly but the heavier red wire is the opposite way around on the original wiring harness so i switched them around before i soldered onto the harness. my original conectors looked like they had spent the last 21 years at the bottom of the atlantic along with the titanic when i unplugged them for a plenum pull !
  20. Or use inner brake lights for fog lights using a two way relay. Jeff TT has a post on here showing the wiring diagram.
  21. Redundant multi plugs on the off side inner wing next to the hicas valve would sugest the car was originally an auto.
  22. Hi Mate contact this guy Wheels UK on 02476367744 he will sort it for you
  23. Hi Guys, I have greddy oil temp & pressure gauges fitted. the sender units are fitted to a sandwich plate that will not take a genuine nissan oil filter without emptying £50 worth of silkolene all over the floor ! I have spotted 2 blanking plugs on the oil tree above the oil filter one of them has a 10 mm bolt in it the other has an allen headed blanking plug. Is it possible to use these 2 for the sender units and do away with this naff sandwich plate ?
  24. Or just get the proper ones from MJP
