Munny975
Everything posted by Munny975
  1. Well here is mine just so you can see the difference if need be i went from this To this Lighting and picture quality help but you get the idea
  2. i know it has to be behind the front wheels legally and as said by WelshZ cant protrude out too much
  3. That search button is a wonderful thing you know :) http://300zx.co.uk/forums/showthread.php?t=129766&highlight=profec+setting Enjoy
  4. From that angle it looks kinda good
  5. You have said it yourself :) Now go out and get a manual Zed
  6. just put a ruler on your wheel (Outer rim of the alloy) and measure the distance between there and where you want it to be (Tight with the Arch lip or sticking out) then get the closest one to it! You can usually get like 10mm, 15mm, 20mm, 25mm which should accommodate you no problem! All depends on what wheels you have on already and their offset
  7. ill still be there but not in the Zed as some idiot neighbour of mine reversed into my car door making it look like this :(
  8. Brakes are probably the one thing that you never want to go budget on as remember this is what stops you from smashing into the car in front of you every time you press that pedal :)
  9. Zeds are front heavy... reducing weight on the rear is only getting to make that nose heavier and you wont be worrying about oversteer as much at high speeds but understeer :) keeping it is a good idea, adjustable camber on the move is a rare piece of kit these days! it was the f1 tech of its day too :)
  10. i am, as stated i cant afford to go to the **** event so i will still do this Mini meet :) See whoever comes there!
  11. Just take them off completely! 2mins and looks alot better :)
  12. I am friends with a few guys on this forum (http://www.tbdevelopments.com/forum/index.php) you have to register (free) to see any of the info but they have their own store which sells mr2 stuff so they will definatly be able to sort you out and get you on your way :) Good Luck
  13. Just found it all Mikael! DOnt think i can afford it after i get back from this trip im on in Miami! Weather is beautiful down here :)
  14. Which midlands event and where? perhaps we move location to add spice to the day?
  15. If you were going to paint it, wouldnt you buy the fibreglass one he is offering as it weighs the same, and is easy to paint compared to painting over CF! Also you have to note that our cars are already front heavy, so by making a bigger front to rear weight distribution you are only to upset the handling more and more. Global weight reduction is justa s important as correct weight distribution. :) Plus as all the weight in the front you would suffer major under-steer, so you would have a RWD car that handles like a FWD LOL!
  16. 1. Scotty300zx 2. Munny975 3.mike j . 4. Phill82 5.mid-wales zx
  17. Try an Engine Oil flush i have used it ages ago and it worked a treat. (CLICK ME) Far cheaper alternative that if works saves you a truck load and if it doesnt puts you like £30 out of pocket no biggie! Also as you said earlier a slightly thicker oil should do the job to lube them back up properly
  18. Sounds sweet with me :) im in! 1. Scotty300zx 2. Munny975
  19. hell i am leaving for Miami for 1week this THURSDAY! i was scared about it, loosing my flights, monies everything! Heard another big puff came out the volcano this morning i was like ahh sh*t thats it, but once i read the news on Sky News (like 2mins after publishing) i packed my suitcase ready to rock :)
  20. Arent the stock boxes able to handle up to like 600/700bhp?? Read a S13 build by a pro it was on like 700bhp running the standard Z32 manual gearbox! Or am i imagining things?
  21. From your rides section it did make me chuckle! I think you meant to type Naturally :hammer::hammer::hammer::hammer:
  22. looks like Kellogs Corn Flakes XD Sorry to hear for the new owner! sure once its sorted he will be fully entrusting it all again :)
  23. Check the physical wiring of the fuel pump as mine melted during a road trip in europe! Its located under the boot carpet and under the spare wheel if you still have it! That or check Crank Angle Sensor (Although fuel is pumping at this point) tiny little plug underneath boost pipes on the right hand side of the engine! Other than that recheck your fuses
  24. Its up to the Birthday boy!!! Come on dude what time do you want to kick this day off? Being a brewers fayre (if my suggestion is taken) it is usually busy on a Sunday afternoon but there will still be plenty of space for us :) Could always do a Mid-day start there for a few hours then all go our separate ways. Sound cool?
  25. If you read the instructions manual it explains what each function does on the boost controller. If its a long delay your 'Gain' may be set to a funny %. If you state all your settings on boost we may be able to see it clearly. on my High boost i set it to 28% which boosts quick and gives a nice punch but runs out of puff around 5500rpm.
