The Dark Warrior
  1. Good question. How do I tell this? Does it still sound like the PTU? or not now? :confused:
  2. The fog light switch on a UK spec car is under (I think) the heated rear window switch on the binnacle. Ivan
  3. Whats wrong with the old ones? Ivan
  4. Cheers boys. I've found the problem now but just got to find the cure. The drivers side rear coil pack connector isn't doing anything. I disconnected it yesterday whilst the engine was running and it didn't make a difference (usually revs drop etc.) so thats the problem. Now the question is whats the cure? PTU? MAF? Checked it for corrosion - none. I just need the cure now please. Ivan
  5. Cheers mate. Does everyone else think it's this?
  6. Well I think I have at least one answer for you.... 1. Thatcham approved means it can withstand an attack for a certain amount of time and not indeffinately. If someone wants to nick a car there is no real way to stop them totally. 2. A really good produst I've seen is aclled the Auto tazer (sp?). It's one of these steering wheel lock bars and when armed has 50,000 volts going through which arc across it when tampered with. IIRC they were less than £100.00 as well. :cool: Fry the scum!!!!!!!!!!!!!!!!!!!! :xxx: 3. Might be worthwile to stop them putting a extra switch in the ignition system somewhere (as well as the alarm-immobiliser) so it has to be on to allow the ignition to work. Mount it somewhere awkward to find but easy to reach if you know where it is (e.g. spare wheel well/boot area or under seats). You could take the handles off the door and iuse a TVR style push switch & solenoid setup to open the doors. Imagine walking up to a car and it not having any door handles inside or out!? But ultimately as I've already said if they want it bad enough they'll have it away. Ivan
  7. Ah right. Well money's tight at the mo' and my dad's an ekectrician so I'll try to find it. Cheers for that mate. I'll let you know if I want one tho' Ivan
  8. OK mate I'll bear that in mind, cheers. I think the old ones are repairable IIRC.
  9. The Dark Warrior replied to a post in a topic in Events - UK
    I dont know what times yet. I'll have to have a word with the gf and find out what time to meet up. What time does the meet begin? We all need to meet at the hobby horse about an hour before the meet I suppose. I can meet you 2 guy's there if you want. Never been down that way only up A46. Can you get into the carpark from the roundabout? Ivan P.S. Mark if you want anyone to drive your car so it doesn't stay idle you know where I am. LOL :dance: :dance: :dance:
  10. Sounds like a plan. :) :cool: Ivan
  11. The Dark Warrior replied to a post in a topic in Events - UK
    That sounds good ya5een. ;) Only 15 mins from me :p :) Ivan
  12. Yeah sounds like it to me as well. I think the PTU and CAS connectors are pretty clean Cheers Ivan :(
  13. Now all MOT testers have a different view of whats a pass and whats not. Whereas someone will pass something someone else probably wont. It's up to their discretion. If the second tester prodded the sill harder than the first one then he could have caused the hole and therefor failed it. Brake balance could have failed in that time if the compensator valve went down in that time. "Tyre had something stuck to it" Maybe it fell off? HTH Ivan
  14. I have just recently had a problem with missfiring and it's been intermittant and now it's all the time. I have cleaned out all the electric connectors for the coil packs and injectors and it seems to only be running on 4 cylinders if that. Couldn't hardly pull away from a diesel Xantia the other day. Seems very reluctant to accelerate at all now :( Have currently got the battery dissconnected to re-set the ecu. How do I do a diagnostic whilst I'm at it? Vould it be the PTU (series one). The guy who had it before me put a second hand one on in september 2002 so dont know if this is the problem :confused: I do need to cleand the throttles out as they haven't been done for about a year but do you think this will cause such a massive problem? Please help guy's :cry: :cry: :cry: Ivan
  15. Yeah normally IIRC removing the rev limit is an easy way of getting more power out of just about anything. Ivan
  16. Mine almost dies at junctions when I come out of gear. Re-setting the ecu now to see if that cures it.
  17. Wheel bearings? Thats what it is on my car? :confused: :confused: Ivan
  18. I used to work at a TVR dealers and whenever someone came in saying I have a ticking noise it was always leaking manifold gaskets. I recommend getting it up on a ramp/some ramps and looking underneath. The easiest way to tell where the blow is coming from is to hold some paper over what you think is the affected area and see if it moves or tip talc powder or dust down there to see if it bolws away. But it could just be the exhaust bolwing. Ivan
  19. The Dark Warrior replied to a post in a topic in Events - UK
    I'll deffo be up for something
  20. Whereabouts is this guy's (and dont say stoneliegh) :dance: Ivan
  21. The Dark Warrior replied to a post in a topic in Events - UK
    looks like I'm going to be convoying all by my lonesome from Melton Mowbray all the way to birmingham :rolleyes: :rolleyes: :cry: :p Ivan
  22. thats a really helpful link cos mine misses on tick over - always has and now has started doing it whilst moving on. Ivan
  23. Oh me too, me too please :dance: :dance: :dance: :dance: Ivan
  24. Your Superhero Identity For Today Is: Name: Black Panther Secret Identity: ivan taylor Special Power: Incredible Ears Transportation: Nuclear Submarine Weapon: Psychotronic Blunderbuss Costume: Leopard Skin Skin Sidekick: Jumpin' Jim Nemesis: Melvin the Crafty Tragic Flaw: Fear of timber wolves Favorite Food: Cheetos
  25. Hhhmmmm braided hose..... now theres an idea. Might try to get some cheap. The ones that are gone on mine are the ones near the top of the diff.
