JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 132.2k
  • And they have arrived !
On 02/07/2023 at 20:28, JaiKai said:
So the zed is now jacked up.
Managed to do loads on it today, started working from just after 9am until 7:30 or so.
Wow so nice this 👏
Nearly done, just the starter, exhaust and a few little things like wiring for the wide band sensors !
All fluids apart from gearbox has also been topped up which i'll do after i go get some.
Also had the first blood of war an hour ago when i stabbed myself with a screw driver taking a fuel hose off.
Spot the man bandage; only the best !
Tonight on JaiKai Tv....
Last night i managed to get nearly everything done apart from some of the fluids.
So that would include :
starter,
clutch piston,
Exhaust,
Radiator,
Front cooling fan,
Inter-cooler pipes
All ready for first start i managed to get the ground harness cable attached to the gearbox and installed the battery for first start.
I removed the fuel pump fuse so that i can prime the oil in the system and connected the battery up.
The zed came alive and starting chiming with the doors open and the interior lamp turned on for the first time in 3 years.
Quick check over everything we are ready for first crank..
And we get nothing, nadda.
Spent a further 2 hours goin over all cabling and checking the ecu but she simply wont crank over.
I'm thinking now either i have a power issue going to the starter or my starter has simply jammed.
Gave in for the night and will likely need to do some diagnostics another day.
I'm not very happy chappy at the moment but hopefully its something simple.
Latest troubles.
I think one side of the engine isn't firing and then it fuel locks - just a guess.
I saw an oil leak on the passenger side turbo as well as a smell of fuel.
So I disconnected the test pipes and I would say half a pint of fuel poured out the exhaust.
Done the same to the driver side and it was bone dry.
In you case I would change the oil, you have spent enough time and money to take any more gambles.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
I know how difficult it is by yourself, before you start the fuel pump you will have to try and make sure all spark plugs are working, make a checklist and work through it slowly.
all the best and good luck.
Tony
2004 BMW Z4 30i
3 hours ago, Gaz 300 said:
I think you need expert help mate is there anyone up there in Scotland that could help you.
I think so too.
Lee, can you imagine how you’ll feel if this goes wrong and engine 💩 itself again?
Recovery to Bristol, gotta be. Have it done right and finally enjoy her!
Whatever it costs to have Jimmer get her sorted will be minor compared to how much it could cost if something doesn’t go to plan!
Whatever you decide to do I wish you luck with it 🍀
6 hours ago, Akita said:
I think so too.
I second that 100%. Jimmers labour and machine shop costs were a small fraction of the total build. Yours and most people who rebuild have a similar parts list / cost I had, so I would not want to risk having to buy them all again. Even if you have to wait to save to get Jim to sort it, I’d do that.
On the Link ECU, I had to get mine trailered to the tuner to map it first before we could drive it. Not sure if you already had a map before with this set up? If so, then should be ok to start and run. Tuner said to us do not attempt to drive it due to the new set up (cams etc).
Edited by Raja93
Is there any sort of diagnostics you can do with the ECU.
2004 BMW Z4 30i
3 hours ago, JaiKai said:
My tuner said we need to get it started on the base map last time before i took it up to him.
Its a big expense to get it trailer'd up just for me to bring it back.
I've swapped out the oil just incase but as the turbo seal seems to be leaking i may need to pull the turbo now.
As said, it’ll be an even bigger expense if you continue to bore wash it with fuel, the build is being compromised! Bite the bullet and get it done properly so you can enjoy this car once and for all. 😎💰
At the moment, it feels like a bit of history repeating?
