It depends what hoses you buy. I think 99% of kits connect at the copper pipe (which you can buy new from Mike for relatively little). Danny had a kit made up that joins straight to the caliper but they're no longer available. Be careful what kit you buy as there are some kits listed for the 300zx which in fact aren't compatible.
I used the drift works ones, they replace everything g back to the hard line on the car. Downside is tough that they don't have the rubber retaining gromits.
I replaced my hard lines Lee. They're pretty inexpensive. I personally wouldn't fit SS lines straight to the calliper especially if they didn't have the correct fixing points.
i'll likely order these in from concept next week.
Although they don't list the rears do they have similar pipes ?
Its a similar arrangement....the little metal pipes will be different length tho.
If you are fitting braided lines direct to the caliper you will need a banjo type fitting at the caliper end and as Si has already stated they WILL need to be supported.
Making the little metal pipes is easy and very cheap and IMO is an easier solution as you dont need braided lines with banjos just the conventional Nissan style side clip fittings
Just use these mate.
http://www.zcentre.co.uk/index.php?page=shop.product_details&flypage=flypage.pbv.tpl&product_id=20&category_id=2&option=com_virtuemart&Itemid=7
It looks like you still have to use the hard line but at the caliper but just get them made locally. I had a pair or hard lines made for my old car like this and it cost pounds, really not expensive. Just found a local hydraulics shop.
Edited by Stephen
I'm not sure if it was a 1off, but Simon bought that Zcentre kit and it had incorrect fittings.
Correct. I need to speak to Luke and get it returned as the fittings were M/F not F/F.
Only one rear pipe is still available, I can't remember which side.
