HarryCy
Premium Member
Everything posted by HarryCy
  1. Some random pics
  2. So updates ..fixed most of the above… Brakes are amazing + ebc red stuff pads Car now is manual since November 2025 Has stillen sway bars front and back. More sound deadening and amp installed Window sliders fixed, new front fog lights installed Some interior trims tidied up and Hks boost control installed because I had it sitting near by😁🤷 Parts arrived from USA… thanks to czp 👌🏻 Intercoolers, aluminium radiator, oil cooler 19row Link ecu / haltech dual wideband. ( mfd28 for gauges) and sensors , boost solenoid Arm 320 lb fuel pump with new assembly.. 850 late side feed injectors, r35 coil pack and adaptors Egr delete kit , second apexi air filter 🤞🏼 they will be installed by the end of the year.. also energy bushings almost done need to install the rear subframe and differential ones .. power goals safe 430/50 bhp until the turbos give up 🤷🫣
  3. So driftworks front camber arms installed and added abit so the wheels will come closer to the upper fenders.. tyres are also installed Suspension is better adjusted . Problems occurred.. fuel gauge decided to go for holidays and stayed there.. jobs to be done need steering rack bushings and tie rod ends need replacing need to order the above.. Oil and oil filter needs changing possible 5w40 Bleed / replace the hydraulic fluid Bleed/ replace the brake fluid.
  4. Things move slower than expected now that I am back home.. updates.. Installed the gktec fan ( it’s loudish) Apexi filter is stalled Front strut bar installed Mono steering installed.. Xeon lights and ballasts Left to be done : rear and front drift works camber adjustable arms.. Tires to install.. 370z brakes to be installed Rear strut bar Manual gearbox conversion..
  5. Also Japanese cheap workmanship .. rear Oem struts where blown and rubber spring spacer was used to stop the struts bottoming out lol Lifted the front and the rear passager side blown and started leaking initially thought it was the fuel tank 😂 Front squick stopped and car is now solid 🤗
  6. Me suspension installed/ instructions for the rear struts was non existence.. took it in and out 3 times both sides ended up reversing the oem rubber with the oem bump stop other wise the kw provided washer kept making nose due to empty space between strut and top mount 😤😤 it now feels amazing but so much money and no proper installation instructions.. suspension feel 9/10 instructions 4/10 Suspension tuning 7 /10 Due to annoyance not many pictures taken 1 video on YouTube did not showed the assembly of the rear struts … That’s how the car sits at the moment
  7. A friend around is also a nice add on
  8. Back to Cyprus ! so front tension rods finally installed after fighting with intercooler pipes and sway bar so ..much fun but the braking shutter stopped and the car feels solid .. just need to find a way to install the plastic air deflectors for the brakes 🤪 Plan is clean it tomorrow and make them gold wheels shine again 😁
  9. Cool 👌🏻 thanx
  10. Since I the gk fan I decided to ask before I act .. Looking for a clutch fork mine is rusted and looking sorry .. any thoughts on the cast iron one from a 350 z ?
  11. Thanks man parts received .. as described.. respect ✊
  12. Hi 👋 .. I would like the front bumper/ rear bumper / Sideskirts and radio Basel if possible ..
  13. I think it uses the oem arms ..but I will delete later on for now I am just getting what I can before I move back to Cyprus I I
  14. Hi I have read all the conversion chats and watched all the videos but … I can not find any info regarding deleting the gearbox computer unit GCU / transmission control module any info is welcome thanks in advance
  15. Also got the Stillen hicas delete from ebay and a gktech en/vg clutch fan and an spec air filter from Torquen 🤞🏼 it’s not going to take 3 months to arrive as the brake adapters 🤞🏼🤞🏼🙄
  16. More updates due to a friend backing up to his manual conversion I ended up with the parts.. manual gearbox from a TT, with short shifter shaft 1/2 from the manual, vacuum pipe Aftermarket light Flywheel used Sandwich plates, clutch pedal slave clutch cylinder with braided clutch line na master clutch cylinder. ordered the front and rear oil seals ordered a gasket for the front reverse light sensor due to being unusable(cut plug) got the staff from Ihtar in eBay Rev it Up with us.
  17. And the adaptors for the front and back
  18. Btw I got the JL c1 speakers and I queried if I need an amplifier.. very happy with the results as is just thinking to add an integrated amplifier/woofer for bass low frequencie and leave the speakers alone as a high frequency controlled by the head unit Less wiring and you will need this https://www.ebay.co.uk/itm/185251812710?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=g_UaOp-ZS5a&sssrc=4429486&ssuid=bWDN5m4JSrq&var=&widget_ver=artemis&media=COPY
  19. I did a search on that every connection to the speakers will have 4 wires on the connector when you open the housings the speaker is connected as usual with 2 follow this 2 and you I’ll find the speaker wires 😉
  20. And interior lights https://www.ebay.co.uk/itm/144409331547?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=IzM6lhqPRJS&sssrc=4429486&ssuid=bWDN5m4JSrq&var=&widget_ver=artemis&media=COPY
  21. https://amzn.eu/d/az2iRB4 struts Leds https://amzn.eu/d/9saQ0nS https://amzn.eu/d/3xMEELc https://amzn.eu/d/3hjem6Z https://amzn.eu/d/bdPWl5a quality mixed medium results amazing happy hunting 😅
  22. 🤞🏼🤞🏼 need to get back to Cyprus to continue the project 🙂‍↕️ back in uk now enjoying the snow..
  23. Hi .. struts I got some from Amazon Chinese made ones not great quality but do the job so 45 pounds job done..LEDs are miss and match but I will try to remember from my eBay purchase history I am missing one I do need to swap my lefts strut oriantation
  24. Welcome lovely car and colour 👍🏻🤩
