pioneer
Everything posted by pioneer
  1. Many thanks for pics,are these located at the side but top of inner wing.Mine has lambo hinges if so they must have welded the hinges in front of them hence that would explain why the water cant escape,many many thanks for your help matey.
  2. Thanks for reply,ive had dash out,wing off,scuttles and wiper mechanism all off and still cant see what nissan did to let the water escape.There is no rubber flaps on mine and some how if you pour water into the bulkhead,it leaks both sides into the car through the inner sills,which i no isnt good,many thanks Mark.
  3. Hi Gaz i messaged you asking how much for membership,you havent replied yet matey,also how do i add pics to a thread,many thanks Mark.
  4. hi thanks for reply,yeah targa drains and matrix all good,ok dont think im been cocky,but there are holes in the scuttle trim so water does go through it,so there has to be holes for it to escape,cheers anyway,seems no info on this any where or pics.
  5. Hello everyone,does anybody no how the water drains out of the bulkhead under the scuttle plastic trim where the wiper motor sits.For some reason i have water coming in both sides of the car in both corners of the A pillar,its not the targa drains there both connected and cleaned out.The only info on the drain holes seems to be just for the targa drains,many thanks for any info.
  6. Thankyou for the reply,how much is membership please.
  7. Hi Gaz how do you start a new thread,many thanks Mark
  8. Hiya would you no where the water drainage holes are from the lower scuttle under the windscreen please,thanks Mark.
  9. hi what shocks are fitted,if not std let me no please,cheers Mark.
  10. Thanks for reply,Jeff posted me a diagram of where they go,but still doesnt explain why i have blue coming from sensor into engine harness and somewhere changes color to yellow/green at clocks and everything looks original,but no continuity from blue to the yellow/green.So without undoing the harness which is a last resort i might just connect the blue wire to a new wire straight to the y/g from clocks,cheers.
  11. thanks ,but the wiring is original so obviously there is a problem seeing as i only have continuity to the yellow/black wire from sensor and nothing from the blue to any wires from speedo plug,cheers.
  12. yes will do that thanks,but the fact i have no blue wire to clocks is confusing me and only have continuity from the yellow/black wire cheers
  13. many thanks for your reply Jeff,so regardless of wire colors as i have no blue wire ,where the pic shows blue i have a yellow/green and across from that a green/red.The only same colors as your chart on mine are the black,grey,yellow/black and blue/black,also i have 8 wires and the pic shows 7,also when i check for continuity frm the sensor plug i only get it to the yellow/black,the blue from sensor plug end doesnt seem to end up at the clocks at all,so should i just connect a new wire from the blue to the yellow/green which is the color on mine instead of blue,would upload a picture but dont no how to on here,many many thanks Jeff for your help.
  14. Hi everyone,for some reason my speedo has stopped working,checked the sensor all is fine,when tracing the yellow/black and blue back to clocks,there is no blue wire on speedo plug,.So now i am stumped as i have yellow/black,black,yellow/green,green/yellow,yellow/green,green/red,blue/black and grey.All the wiring diagrams say the blue and yellow/black from sensor go to the cluster,any help much appreciated please.
  15. Hiya jeff hope your enjoying portugal,for some reason my speedo has stopped working and my engine check light wont work,bulb is ok and the wire from the ecu to the clocks is a good connection.many thanks Mark.
  16. Hiya Geoff can you tell me where the drain holes are on the metal wiper panel please,when it rains ive got water down both sides of car ,thought the drain hoses were brocken but that would be to easy lol.I currently have dash out,fuse box and air con unit trying to see where the holes are.without cutting the top off of the panel im stumped,just wondered if youve ever looked inside or cut the top metal bits under the scuttle plastic panel bits,cheers Mark
  17. hiya just wondered if you knew where the drainage holes in the scuttle bulkhead panel are located,as mine must be blocked,as i have water staying in the scuttle,many thanks
  18. Hiya Geoff can you tell me where the drain holes are on the metal wiper panel please,when it rains ive got water down both sides of car ,thought the drain hoses were brocken but that would be to easy lol.I currently have dash out,fuse box and air con unit trying to see where the holes are.without cutting the top off of the panel im stumped,just wondered if youve ever looked inside or cut the top metal bits under the scuttle plastic panel bits,cheers Mark.
  19. on the top row there is a row of 10a fuses should be third one but just check all of the 10a on top row.
  20. Hiya have you checked fuses and are you connectors in the pods in firmly,and what was problem before.
  21. Thats good to no thanks geoff,so you finally did it,good luck to you matey enjoy the sun
  22. just been honest dont no how else to start a post,thanks
  23. Thanks for reply,ive changed them to blue,what should i change resistor too and which one is it,many thanks Mark
  24. Also are you the one who does led bulbs in the switches,as i have done it to mine,only problem is the warning light for the rear window goes out when you put the lights on,and i cant get my engine check light to work,bulb is fine,checked wiring to ecu all fine.
  25. Thats what i thought ,they need a chassis number for a fuse lol,thanks for the pic ,its a big shame now geoff has gone from zedworld,thought jamie would have kept it going
