Tango450
Everything posted by Tango450
  1. I was in the RAF Regiment. jumping out of helicopters, and doing the three peaks before I found out mate. Now the most I do is drill the G/F
  2. Feeling pale and faint is a sign of low sugars (unusual as it's usually high when first diagnosed) however feeling exhausted is a sign of high levels Shame you weren't oop North I could have tested your levels for you. Go to your GP, they can tell you in 30 seconds if you are or not. In fact I took my little boy to A&E to have him tested the other day as he had symptoms. was in and out in 15 minutes and thankfully he was clear
  3. Welcome to the club mate......From experience prepare for a long search to find a decent one for good money. My advice....Buy from the club (even though I didn't LOL)
  4. Hair loss wasn't a problem I had. If your sugars been high for a while, fatigue will be a problem. The other main indicator is your eye sight. Mine deteriorated quite badly, I struggled to red anything at a distance. And the other stuff mentioned already, Constant thirst, going to the bog a lot. And the worst thing which has already been mentioned is I thought my cock was gonna drop off.
  5. I'm a full blown Diabetic mate....have been for about 5 years. Anything you need to know just give me a shout
  6. I know how you feel bud...I missed my wife once, the friggin bullet hole is still in the door frame :x:
  7. Let me have your PSN and if you have time between Craigs Z I'll send you an invite
  8. Are you online on the PS3 if so what's your PSN ID, just got COD4 :hyper:
  9. Welcome to the club mate
  10. What Stu said.........Stellaz has been good enough to look at one for me. in the end I got lucky. Picked one up cheap and the only problems I've had is a dodgy window and a knackered coil pack. There is a lot of crap around, you would be safer buying one off a member
  11. Big Thanks to Ian...........Stereo now fitted and working. Only thing is I've got a hiss through the speakers which sounds like interference, the aerial isn't fitted yet so I'm hoping that's it. If not has anyone had this problem after fitting an aftermarket system
  12. Genius :bow: I'll have a bash tomorrow. I'll either be the bloke with a big grin when it works.....Or the crispy looking dude smoking in the front seat if it doesn't
  13. It runs into a silver box along with the aerial. I'm assuming your first guess was correct and it controls the function of the aerial.
  14. Cheers Ian I'm in Durham. I've ordered an adapter off ebay so hopefully that will make it a bit easier. The new stereo has the speaker connections then the following: Battery power Ground Ignition Power Power antenna If the old one has a feed going to the amp, how do I get round that in order to keep it fed. I'm not concerned about the auto changer as the new one will be running an Ipod. (may find some other goodies to fill the gap:D)
  15. Cheers Ian The switch was just sitting behind the dash among the other wiring. The odd thing is it has 2 settings etched onto the switch.....On & On :confused:
  16. Sorting out knackered drivers window Fitting new sounds getting a quote for a full respray Looking for some nice new wheels
  17. I'm trying to fit a new system to the Z. I've searched the site and found a wiring guide, http://www.300zx.co.uk/forums/showpost.php?p=1254445&postcount=11but what it lists as Z wiring does not match what is coming from the back of my original unit. Some pics below of what is currently connected. And this which is not connected And does anyone know what this switch is for It's got a cd multichanger currently connected. All of which is standard JSpec I believe.
  18. Greetings from my jollies:D The Z has started misfiring on one or more cylinders, not all the time and usually after it's been stood for even an hour or so. First time was in the wet. second time it was dry. Both times it has cleared itself after 10 minutes or so, hoever this last time it hasn't as yet Any ideas what's causing this and how can I find out which cylinder(s) it it is Cheers:confused: It's a 93 N/A manual. BTW I'm on a rip of tertminal that charges a quid for 10 minutes. Hope you guys can point me in the right direction. I'll drop in later
  19. I've got a link for you. Takes you directly to the end of a large pole.....Arse first
  20. This nugget please http://www.300zx.co.uk/forums/member.php?u=16310
  21. ^^^^^^^^^^^^^^^^^^ Can we not stop these muppets. He's going through every thread :slap:
  22. What do you think http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=220465609009&ssPageName=STRK:MEWAX:IT#ht_5827wt_1165
