Daves_Zed
  1. Have a look at the Pick-Up :D Dont look very high though, could be tricky getting in :D
  2. Daves_Zed replied to a post in a topic in General Discussions - 300ZX Related
    I'm sure someone else will correct me if I'm wrong, but this should be checked for the BIMTA cert, on new imports (not sure when this came in)
  3. Assuming that he was using a trolley jack, then I agree that he was wrong in jacking it by the use of the sill position, this is only for the car supplied jack. Jacking Points Also look at page 23. HTH
  4. But will look even better and more exclusive on a Cherry red one ;)
  5. Rear Fog switch that I have (not my pic or car) Info on this thread http://www.300zx.co.uk/forums/showthread.php?t=29643&highlight=fog+switch
  6. You are indeed right, but then again, i cant afford to live in that one either, as my ex wipped me out!! :rofl: :rofl: :rofl:
  7. Anyone would think I'm being paid for this, I wish, just thought they were a good company :D
  8. Do you mean These Ones Stu??
  9. Yeah, £10,000 is a lot of money, but you should have seen it, it was fooking masive :D It looked something like this, Cant remember the exact measurements, but it was in the region of 5.5 metres x 3.8 metres (ish) None of this 9 foot x 9 foot crap you normally see :D
  10. Pete If you have some decent DIY skills, then it isnt rocket science to build it yourself..... I did :D I brought a 16sqm floor area L shape victorian in UPVc, and along with bricks, plastering, all the electrics and flooring (in fact, everything) it cost just under £10,000. If i'd paid for a company to do everything for me, I'd have paid at least £25,000. I'm sure you can see the advantages in doing it yourself!! ;) The only job I didn't do myself, was the plastering, everything else was straight forward, with excelent, supplied, instructions and diagramms/photo's. Classic Conservatories were the people who supplied mine, they are part of the Baltic Pine group. Good delivery and price, along with service. Out of some 100+ parts, only had to have two replaced, was sorted quickly and efficientley.
  11. Just stole this from another web site :D A RIP-OUT RIP-OFF GUIDE FOR WORKSHOP MANAGERS TO HELP MAXIMISE SERVICE REVENUES After extensive research, Dishonest John presents 26 top tips for dodgy service managers who prefer to put profits before punters. The Keyfob Caper Tell the punter that his remote control keyfob needs new batteries but for it to work again it also needs to be re-programmed at a cost of anything from £40 to £85. The Bulb Blag Phone the customer while his car is in for service to tell him that among the additional items needing attention a bulb has gone. He will think, "can't cost much" and will agree to a bulb replacement. Then charge him 15 minutes labour at £60 an hour to change the bulb and another 15 minutes for the fitter to obtain it from stores. The Screenwash Scam Always automatically charge for renewing the screenwash additive. Even if it the reservoir is full when the car arrives, leave a bottle of additive in the boot and still charge for it at an outrageous rate. The Multipurpose Lubricant Leglifter Similar to the screenwash scam. Always supply a spray can of multipurpose lubricant at every service, and charge for it, of course. The Oil Filter Flanker Instead of changing the oil filter at a routine service, tell the fitter to simply give it a good clean over with a rag. It will look like new, the punter won't know any difference and the garage will save 15 minutes obtaining the new filter from stores and fitting it, plus, of course, the cost of the filter. The Fluids Overfill Charge the customer for an quantity of oil, coolant, ATF, gearbox oil, brake fluid, etc over and above what the car will actually take. Very few punters ever spot this and if they do, tell them it's a clerical error, revise the invoice and refund them the extra money. 99 times out of 100 you'll never have to. The Major Component Confusion Never, ever repair a major component. If, for example, an automatic gearbox has a problem DO NOT INVESTIGATE THE CAUSE. Instead, simply quote for fitting an entirely new automatic gearbox. The fault may be nothing more than a duff solenoid in the valve block, but don't waste time with a £200 job when there is much more profit to be gained from fitting a new autobox at £1,750 plus. The Wiper Wipe Out Always phone to suggest to the customer that his or her wipers need replacing, then not only charge a 100% margin on the replacement wipers, but also charge 15 minutes labour for fitting them. One reader was quoted £104 for fitting a pair of new wipers to her Alfa Spider. For a Renault Espace, it was £40 plus fitting. The Seals Scam If the engine or gearbox is suffering from a slight oil leak (or even if it isn't and you can induce one) quote the punter for expensive new gaskets or seals, preferably internal shaft end-seals. They usually fall for it, but watch out for the bloke who has a handy mate with a ramp who can spot that all that's needed is to tighten a few nuts. The Brake Blag During a routine service, 'discover' that the front brake discs are wearing thin and are in need of replacement. Punters are getting used to having to replace discs every 30,000 miles, so even if the discs are still in good condition you will probably get away with selling the parts and a nice fat labour charge. The Calliper Con Alternatively, if the brake discs really are wearing thin it may well be due to sticking or rusty pins in the callipers leading the pads to bind on. Whatever you do, don't replace or clean these pins. To maximise replacement revenue, wait until the customer comes back with another worn thin pair of discs, then tell him the callipers need replacing as well as the discs and pads. The Battery Blether If the punter complains of slow starting, that's your cue to flog him a new battery. Persuade him that a' maintenance free battery' cannot be topped up or re-charged and definitely don't mention the battery plate re-conditioned that can be purchased from the banner ad on the homepage of http://www.mysterymotors.com The Sundries Scam Always charge a figure of between £2.50 - £5.00 + VAT for 'sundries' and if the customer asks what they are, tell him disposable wipes, disposable rubber gloves and oils and greases used in small quantities on things like door locks and hinges. The Over-the-Top Oil Earner Even though the workshop's engine oil comes from a bulk tank at a huge discount, still charge for it per litre as if it has been supplied in individual litre bottles. The Warranty Maintenance Muckaround If the customer has a used car warranty requiring the car to be regularly serviced at a franchised dealer's, this can be a real goldmine. Be careful to find a long list of repairs and replacements, none of which are covered by the warranty, but all of which must be made for the warranty to remain intact. The Drivebelt Dodge "Check auxiliary drive belts" will usually be included on a service schedule. But no mention will be made of making any adjustments to the tension of the belt, so this should be charged for at the rate for at least 15 minutes labour. The Low Sulphur Scam If a punter shows up with a non-functioning diesel pump, tell him the reason is wear due to the lack of lubricity of Ultra Low Sulphur Diesel. The problem may really be no more than a chafed cable to the pump, but it's much more profitable to sell him a new pump and fix the chafed cable without telling him. The Clutch Con Sudden clutch failure may be due to the pressure fork fracturing rather than failure of the clutch itself. On many makes and models, the fork is easy to get at and replace without any serious dismantling. But the customer probably won't know that. So, if a clutch appears to have failed, always quote for a complete new exchange clutch and, if the problem is really no more than the fork, fit that as well and charge extra for it. The Hidden Faults Hoax Find things wrong that the punter can't see and check up on. Such as a broken engine mount, a duff tailgate strut, a faulty water pump, a fractured door hinge mounting, a noisy wheel bearing, a worn steering rack, etc., etc. The scope here is as wide as your imagination, but check the car's previous service sheets to make sure you haven't tried the same stunt with the same component before. The Electronics Earner If the car is not running properly, tell the customer you will perform a complete diagnostics check on it. This will usually isolate the true cause of the problem, but instead of fixing that replace one of the other components in the electronics or the fuel injection system. The customer will then come back and, after pleading 'trial and error', you will probably get the chance to rip him off for replacing something else which may or may not solve the problem. The Loose Connector Con Often, all that will be wrong is that a connector plug has come loose or got some moisture inside it. Never ever admit to this, especially if it's the multipoint connector to the ECU. Always diagnose that the ECU needs replacing at a cost of £500 plus. The Lambda Laugh If the diagnostic interrogator and an emissions test isolate the exhaust Lambda sensor as the source of the problem and simple cleaning would cure it, instruct your fitters to replace it. Though Halfords sell universal fit lambda sensors for £30, some manufacturer prices can be very high, especially for the more complex sensors in Toyota Carina E and Avensis models. Always go for the maximum obtainable revenue, never for the minimum needed to cure the problem. The MOT Megablag The most fertile area for unnecessary repairs is the MOT test, especially if your garage is an appointed MOT testing centre. Always give the car a cursory pre-test, find it needs a few bulbs replacing and phone the customer to get permission to replace them. Then, depending on the type of customer, in the test itself make sure the tester finds things like split driveshaft gaiters, worn suspension bushes, loose brake pipes, etc. But whatever you do when applying this blag, make sure the car has no genuine major fault which would lead it to fail the test. Punters will almost always be so relieved that their car has got through its MOT, they won't mind paying for £50 to £100 worth of repairs to get it through the test. But if the car needs major work, you won't get away with a package of minor add-ons. The Indecent Incentive Always incentivise your fitters with things like free holidays. You have to make them prizes for tax purposes, but sending a fitter and his family off to Bali for a fortnight costs a tiny percentage of what you're going to make from his ingenuity in finding lucrative non-existent faults. He'll be happy for six months working towards his holiday in Bali and you'll be raking it in without having to pay him expensive cash incentives. Suggestion Box Don't even dream of it. The only way to make cons like this work is for everything to go unsaid. Keep This Under Your Hat Keep this document firmly under lock and key, preferably in the safe. Never leave it lying around on a desk. Preferably, commit it to memory then destroy it. Do not let it fall into the wrong hands or your game is up. Do not discuss it with your wife or girlfriend. Remember, careless talk blows blags.
  12. Thats the Zed I saw in Blackpool the other month, as I was pissed at the time, only remebered the colour and the spoiler :D
  13. Chris, First there are only two reverse light bulbs on the car, one left with two appatures, and one right with two appatures. Second, it depends how much you want your Zed to look OEM, if you do then there are a number of ways that you can obtain Rear Fogs and keep the original look. 1) Rewire one of your reverse lamps to a fog switch, but change the bulb for a red bulb (instead of clear). This keeps the clear lens look from outside. 2) Rewire either the righthand inner brake lamp, or both inner brake lamps to a fog switch. This should be done with a relay, then your 'Bulb-Out' lamp will not illuminate when you press the brake peddle (but will when your fogs are switched on) 3) If you have the OEM spoiler, you can rewire this as your rear fog either indipendentley or, again, with a relay to keep the brake when you are not using the fogs. (my current option when I've fitted the OEM spoiler) Wireing Diagramm For Rear Fogs HTH
  14. It's no trouble, anything to help a fellow Zedder :D Anyway I'm not much good with engines and stuff, but am OK with electrics, so I like to help where I can. Hope you get it sorted.
  15. http://216.144.230.195/Videos/Medium_WMP8/Live_News.wmv
  16. And this one :D :rofl: :rofl: :rofl:
  17. Just found this :D :rofl: :rofl: :rofl: :rofl:
  18. There is one thing that I've noticed, while looking through all the posts this morning (bored, see other post, http://www.300zx.co.uk/forums/showthread.php?t=35433 ;)) and that is that we seem to be getting some TROLLS. People coming on here specifically to caurse trouble!! They are either just trouble makers, or are already members coming in under a different user name, again just to caurse trouble :xxx: Having just seen a post in Help and Advice
  19. Just checked this out, clicked the JOIN button (to see what would happen) and got the company stopper, bloody typical :mad: Been there, seen it, done that :nelson: :x: ............................. ;) :rofl: :rofl: Thanks guys :D
  20. I'm sat here at work, on the control desk ( well on my chair, at the control desk, before anyone says anyhting about not sitting on desks ;)) and I've been here since 7:30 this morning, god knows when I'll be leaving :confused: I've read all the new posts, so now i'm bored, so can some of you post somthing new :D, just to keep me entertained :D Thanks in advance.
  21. Fosse Park isnt all that far away from where she lives, so I'll have a word with her and see. Cheers Rich
  22. Is there a contingent going on the Saturday for Billings, leaving from the Leicester area? I'll be down that area, picking the girlfriend up, so thought I'd ask :D Although I'm not sure what time I'll be going at the mo.
  23. Greg, I hope this'll be of some help to you, The bottom line is -12vdc, two wires going up to the lamp holders, through the 'bulbs' (lamps), then up to the gearbox and the reverse switch, then to +12vdc (29). Number 21 is off to the Inhibiter switch. It's a straight forward circuit, basically nothing is in the line other than the components you'd expect. So as Oneday has already said, check to see if you have 12 volts at the plug coupler for the back panel. HTH, if not give me another shout, and I'll see what i can do for you.
  24. Low Blood Sugar (Glucose) is called Hypoglycaemia, have a look HERE Where-as Diabetes is High blood Sugar (Glucose), LINK By the sounds of it, it may be the first, but get it checked out, it is important. I used to work with a guy who had Hypoglycaemia, in the bad cases you seem to all others around you like your drunk, and it isnt nice. HTH
  25. PMSFL :rofl: :rofl: :rofl: :rofl: :nelson: :x:
