Reverse Lights
Since trying to fit an iluminated rear panel i wired the live and earth in to the rear no plate light. now my reverse lights arent coming on checked bulbs there fine and cant see a fuse that controls the reverse lights.
iv done a search but its the same old story [reverse switch]is there any fuses
or method to check reverse switch
cheers greg
is power getting to the bulb when the car is put in reverse ?
Greg,
I hope this'll be of some help to you,
The bottom line is -12vdc, two wires going up to the lamp holders, through the 'bulbs' (lamps), then up to the gearbox and the reverse switch, then to +12vdc (29). Number 21 is off to the Inhibiter switch. It's a straight forward circuit, basically nothing is in the line other than the components you'd expect. So as Oneday has already said, check to see if you have 12 volts at the plug coupler for the back panel.
HTH, if not give me another shout, and I'll see what i can do for you.
Thanks for your trouble dave i will take a look tommoz as weather is cack at the mo i will post up if no luck :) greg
It's no trouble, anything to help a fellow Zedder :D Anyway I'm not much good with engines and stuff, but am OK with electrics, so I like to help where I can. Hope you get it sorted.
