Everything posted by ed davies
Brand new OEM EFI Wiring Loom & Leader gears ring and pinion set
I have for sale a Brand new OEM EFI Wiring Loom to fit a 300ZX TT Manual part Number B4011 31P61. This is for an early model car with the first gen PTU and injector connectors (square type). Also included is a 'loom saver' which is an adapter that fits between the loom and the ECU about 8in long, If you need to splice in any accessories you splice into this instead of the new loom. looking for £400 for the 2 items. Also have a Leader Gears 4:10 Ring and Pinion set also new, open to serious offers for this bit of kit, (Will need professionally fitted) Was intending to keep these items for my next Z but came off my Drag race bike and wrecked it, have rebuilt it but need to purchase some bits that are kinda expensive Its a Turbo Hayabusa that kicks out 513bhp cost a fortune to build, it had to be rebuilt.
Update on Colin (Dick300)
Gutted. Colin was a great guy, Thoughts are with you Lesley. Ed
Wish you well mate
Scottish street car event
Hi Paul If the weather is dry the next time will be the 12th and 26th of Oct, need a dry day to try the Mickey Thomphson drag slicks, See you there hopefully. Ed
Yup its bhp per tonne that makes the difference
Cheers the photographer from strathycruise is pretty good, Fast car mag are going to use some shots of the car for the magazine feature of the event should be about the Nov/Dec issue, fingers crossed it makes it
Hi Bud Got knocked out by a kit car called a Supa Busa, powered by a turbocharged Suzuki Hyabusa engine.
Hi Guys Some photo's from the Stratycruise.com site of me and the bus at the street car event, got knocked out at the 1/4 final stage but was pleased with the result.
Hospital
Hi Leslie Sorry to hear about Colin I hope he makes a speedy recovery, Can you let him know I nearly made the final of the RWD class at the ultimate scottish street car at crail at the weekend missed by .3s, I was looking out for colin at the event but sadly realise why he was not there. Best regards Ed
just got a 300
Greetings Bud
Hurst Line Lock / Roll Control fitted!!
Thanks bud would be a big help, I have one similar but lost the instructions
Andy Do you have a photo that shows how the braided hose is attached/plumbed to the servo/chassis. Ed
coolant freeze temp
I dont think you need to be concerned about the freezing temp. If you were to use it without any dilution with water the freezing temp protection is greatly reduced. Rough mixture is 50/50. Retry your experiment but mix it 50/50 with water and see what happens, if I am correct it will still be liquid. It also raises the boiling point of the water to protect the engine when it gets a bit hot. The higher running temp is more likley to be because the engine will still be "tight" as the bearing/contact surfaces on your enginge are not bedded in yet and will be generating more heat untill they are "run in" and reach the correct tolerances, then it will run cooler. have fun Ed
Fao Dick300
Yup just a thrash so should get a bit more tracktime, are you going?
Fao Dick300
Hi Colin, are you going over to crail this weekend 27th April? I will defo be there New Nitrous set up, Mt's (if its dry), car is outside ready to go even bought some extra fuel in case the petrol shortage takes a grip up here. Ed
Zed tried to kill me !
I wish i had read this post before last October, I had not long finished a major rebuild and this happened at full throttle dont know how fast i was going but was in 3rd gear and approaching a sharp bent which went over a bridge. turned the key back but engine did not cut as i had wired the turbo timer wrong (did not earth to the handbrake lever). Took off from the bank at the side of the road through a fence and landed in a field with a well bent wing half the exhaust ripped off and a broken windscreen and in urgent need of clean underwear. Now cable tied and sealed.
who,s going through a mid life crisis
Jesus a Yam Fizzy, now that brings back memories I remember how excited i was when i got mine back in 1979, was up all night as i could not sleep was at the Yamaha dealer 1hr before they opened in the morning standing outside with my new crash hat raring to go. Ed
Hks Dv Question...
Take a length of 4mm vac hose push it onto the black plastic conection on the top. Then splice it into the vac hose using a tee piece that comes out of the rear of the valve, basicly you are joining the two vac lines together. When vacuume is supplied to the top part of the DV it helps keep the valve closed, when it sees boost it opens. It stops the DV creeping open before its ment to open. Ed
help/advice needed please before i put a sledge to my Z
Have you looked at the check valve thats on the vac hose that comes off the balance bar? Is it installed the correct way, the balance bar end is the end thats at a 90deg to the main body of the valve. From the clutch booster side you should be able to blow through it but not suck through it. Not 100% sure its your problem but it could be. Ed
Car Shows and Events
I will give them a try if Clark motorsport cant help. Cheers for that. Ed
Sent off email to Clark Motorsport they look like just the place to build it. Thanks for that. Ed
Hi Colin, I am still alive but have not been to crail for a while (major rebuild) just about ready to do it all again though, will be at the Banzai meet. Do you know by any chance someone who can fit a ring and pinion gear set to a diff, dont want to try it myself incase i get it wrong. ED
For those trying to contact Zedworld
Hi Paul Just came across this post, please pass on regards always found Zedworld very helpfull. Thanks Ed
Anyone in Aberdeen
Will give you a call Fri eve. Ed
Anyone in Aberdeen
Yup I am in Aberdeen with a Twin Turbo, I will be back home later this week, can help if required also have conZult.
