Just a silver Z
After many years of thinking/ dreaming/ window shopping.. it happened ๐Ÿ˜‡
This is officially my 300zx trip , 2+2 , auto .
136400km on the clock full Nissan Japan service history. Work vs xx wheels and a kakimoto cat back exhaust . And working AC.
Edited by HarryCy
Add details
  • Replies 31
  • Views 4.1k
  • A friend around is also a nice add on
  • Things move slower than expected now that I am back home.. updates.. Installed the gktec fan ( itโ€™s loudish) Apexi filter is stalled Front strut bar installed Mono steering installed.. Xeon lights and
  • HarryCy
    HarryCy
    So updates ..fixed most of the aboveโ€ฆ Brakes are amazing + ebc red stuff pads Car now is manual since November 2025 Has stillen sway bars front and back. More sound deadening and amp installed Windo
Obviously mods need to begin with. Car like that so..
firstly some sound upgrades as the 32 year Bose system has seen better days .. Anws pioneer headunit bought but had some issues with previously Alpine iso wires so I had to do a small surgery and tapping ( proper wires/connectors ordered ) and due to rear adapters not arrived in time .. was able to install only the fronts .. some pictures of the saga..ย
When I am back to Cyprus I will fit the rear speakers and decide if I will install an amplifier to the lot..
Further mods / future plans coming up:
Nardi steering wheel
Front tension rods , upper camber arms, alignment.
350z front brembos and custom brake lines
update with leds the instrument cluster
front headlight bulb upgrade thinking of xeon as Oem are โ€ฆ ๐Ÿคฌnot very goodย
some paint work to make her look a bit younger..โ˜บ๏ธ
Manual swab ๐Ÿคž๐Ÿผ
Coilovers ( meisterrs most possibly)
thatโ€™s the list at the moment will see what else will come up ๐Ÿ˜Ž๐Ÿค—
Best I can do .. not the best story teller ๐Ÿ˜‚
  • 4 weeks later...
So updatesโ€ฆ
radio wiring loom iso for pioneer head unit arrived.
rear speaker adapters arrivedย
6in 1 speaker wire for the amplifier arrived
White LEDs for interior and dash arrived
eBay hid set 55w arrived.
t-top interior latch handles ordered /arrived
akebono adapters front and back ordered/awaiting
akebono 370z front and rear callipers arrived
355 and 350 discs arrivedย
kw v3 coilovers ordered/arrived
front hood struts ordered/ arrived
rear boot struts arrived
whiteline front camber adjustable bushes to be ordered.
updated clutch fan to be ordered
for 2025 parts/plans
Refresh bushes and maybe some rear camber armsย
keep looking for manual conversion.. gathering funds for it .
pics will follow when I get back to Cyprus for installationย
brakes and suspension will be installed probably towards the end of 2025
Edited by HarryCy
Nice parts list, Iโ€™m looking to a get a set of KW V3โ€™s in the future, all the German car guys rave about them, great UK road compliancy and brilliant handling so best of both worlds. If youโ€™re after manual conversions, contact Paul Clements at Banzai Breakers. He sells the most comprehensive kits and best quality.ย
Thanks.. I will, btw I wish I could install them as soon as.. but unfortunately I will have to post all the bulky parts to Cyprus .. so it will take itโ€™s time ..and I wonโ€™t be able to give you any feedback as yet..ย
I will post some pictures for the xeon lights/ interior leds etc rear speakers / amplifier and camera installation ..ย
  • 1 month later...
So back home for couple of days and โ€ฆ radio repositioned / wires sorted/ clock in the BIN and usb ports inserted.. LEDs so we can see in the car sorted / rear speaker upgrade sorted..ย
HID installed so we can see outside the car sorted need slightly more adjusting..
Nandi steering and boss installedย
rear trunk and front hood struts installed
tension rods / kw not installed as yet so I canโ€™t comment on them ..
fuel gauge saw the Full sign for 15 minutes and started the downfall as excepted ๐Ÿ˜Ž๐Ÿ˜…
Now the problems are ..wheel hop and shacking when braking after 65km/hr around 40miles/hr
๐Ÿคž๐Ÿผ itโ€™s the tension rods but tbcย
Weird noise like mushing ย on the driver side suspension to be sorted
I'd say you are on the money with the tension rods tbh!
Which dash leds' and bonnet strut kit did you use?ย
Hi .. struts I got some from Amazon Chinese made ones not great quality but do the job so 45 pounds job done..LEDs are miss and match but I will try to remember from my eBay purchase history I am missing oneย
I do need to swap my lefts strut oriantation
Edited by HarryCy
๐Ÿคž๐Ÿผ๐Ÿคž๐Ÿผ need to get back to Cyprus to continue the project ๐Ÿ™‚โ€โ†•๏ธ back in uk now enjoying the snow..
  • 4 weeks later...
More updates due to a friend backing up to his manual conversion I ended up with the parts..
manual gearbox from a TT, with short shifter
shaft 1/2 from the manual, vacuum pipe
Aftermarket light Flywheel used
ย Sandwich plates, clutch pedalย
slave clutch cylinder with braided clutch lineย
na master clutch cylinder.ย
ordered the front and rear oil sealsย
ordered a gasket for the frontย
reverse light sensor due to being unusable(cut plug)ย
got the staff from Ihtar in eBay Rev it Up with us.ย
Also got the Stillen hicas delete from ebay
and a gktech en/vg clutch fanย
and an spec air filter from Torquen ๐Ÿคž๐Ÿผ itโ€™s not going to take 3 months to arrive as the brake adapters ๐Ÿคž๐Ÿผ๐Ÿคž๐Ÿผ๐Ÿ™„
Make sure to check the arms that you are bolting to the HICAS delete bar, might be a good time to replace those with it.ย
Also heard quite mixed review on the GKtech fan so interested to hear how you find it! ๐Ÿ™‚
I think it uses the oem arms ..but I will delete later on for now I am just getting what I can before I move back to Cyprusย
I Iย
Iโ€™ve also heard the same about the GK Tech fan. The Z gurus advise best to stick to OEM fan.ย
Since I the gk fan I decided to ask before I act ..
Looking for a clutch fork mine is rusted and looking sorry .. any thoughts on the cast iron one from a 350 z ?
Edited by HarryCy
It's a worthwhile upgrade from stock. For reference:
https://conceptzperformance.com/czp-upgraded-heavy-duty-clutch-fork-kit-nissan-300zx-z32-30531-cd000-fk-z32_p_9315.php
  • 1 month later...
Back to Cyprus ! so front tension rods finally installed after fighting with intercooler pipes and sway bar so ..much fun but the braking shutter stopped and the car feels solid .. just need to find a way to install the plastic air deflectors for the brakes ๐Ÿคช
Plan is clean it tomorrow and make them gold wheels shine again ๐Ÿ˜
