Project Black Sunshine - The 300bhp NA
Intro -
After more than 15 years of ownership, many great meets, road trips, and track days, my Fairlady is going through a full top to bottom rebuild. During many of the meets I discussed building the ultimate NA with Slick Pete as we shared the love of high revving NA motors. Almost everyone recommends going TT conversion or LS swap as the easy way to high power but I wanted something unique. So after securing some workspace with NickZ32 the tear down began. Its been slow going but continues to move forward.
Will provide updates as I pull together photos and details
Edited by madmarco
redundent
  • Replies 53
  • Views 8.2k
  • Just a few pics covering the tear down plus the last pic I have of me driving the Z from Oct 2017. Engine looked OK when mounted but pretty worn as it was exposed. Bearings showed some wear after over
  • madmarco
    madmarco
    Body repairs were delayed due to my body guy needing an Op but the Sills have finally been completed. A lot more work was required than I imagined, and the complexity of the sill construction was the
  • Engine is home now, just need to add the fuel rails, new injectors, upper plenum, throttle bodies, and then the belts, alternator, etc... Everything should be good to go once the body comes back from
Just a few pics covering the tear down plus the last pic I have of me driving the Z from Oct 2017. Engine looked OK when mounted but pretty worn as it was exposed. Bearings showed some wear after over 200K miles but not bad considering how hard I pushed at track days.
t
Edited by madmarco
  • 2 months later...
Big day today, Z has left the lock up for the first time in over two years. Off to the welder to sort out the rust before heading to full respray. Rust at rear sills is the worst but a few areas need attention. Hopefully after all is resolved she will be good to go for another 30 years!
Posting those pictures of rust was a bit depressing! How about a preview of a shiny new motor and predicted HP model? Looks like 300bhp+ is well within reach.
  • 4 months later...
How’s the engine build going? Really interested to see the outcome of this one.
Engine is home now, just need to add the fuel rails, new injectors, upper plenum, throttle bodies, and then the belts, alternator, etc... Everything should be good to go once the body comes back from paint. Will compile a full build sheet soon. Here's a pic of the motor on my new rolling stand whipped up from spare lumber I had left over from various projects.
  • 4 months later...
Body repairs were delayed due to my body guy needing an Op but the Sills have finally been completed. A lot more work was required than I imagined, and the complexity of the sill construction was the highest the welder had ever seen in a non-convertable, Did you know there are 5 layers of metal in the sill? A few more small jobs and should be ready for paint!
SR Custom Fabrication in Winchester. His work is immaculate. He takes on one project at a time because he has a steady stream of MOT fails that pay the bills. So it takes a bit longer to get the big jobs done. I think is worth the wait, the prices are reasonable, and he is absolutely dedicated to quality work.
  • 5 months later...
About time I provide another update! Complete strip down revealed more rust near the rear hatch hinges and seal. Back to the welder for repair... Engine bay cleared of all wiring and hoses, glass out, and fully hoovered. Went off to paint Monday and should be back in the lock up by Thursday. Then the fun begins with reassembly.
Black Sunshine Z32 NA build sheet -
Cylinder Bore - 87.5mm
Crank Stroke - 83mm
Cubic Capacity - 2995cc
Static Compression Ratio – 12.1
Pistons – Wiesco WD-15481
Rods - Eagle Type CRS6071N3D
Rod bolts – ARP
Main studs – ARP
Head studs – ARP
Cam belt – Gates RPM
Ross Performance Gold series harmonic balancer with integrated 36T
Ross Performance VG30 Crank / Cam Trigger Kit
GT101 Hall Effect Sensor
Polar Engineering Z32 Billet Fuel Rail Fittings: Factory 5/16
DeatschWerks matched set Fuel injectors 550cc EV14S
JWT 500 Series Race Cams, RM5 Solid Lifter Cams AZ32 -TORM5
JWT solid Lifters
Supertech Valves +0.5mm
JWT HD Single Coil Valve Spring Kit
Cylinder head porting
BDE VTC Pulleys adjustable
BDE 3RD Element for adjustable VTCs
BDE Late Style VTC Front Covers - Nissan 300ZX 94-96 Z32
BDE BULLSEYE Adjustable Exhaust Pulleys
BDE SS Exhaust Pulley to Camshaft Bolt kit
Z1 EGR Plates & Gaskets
Z1 Throttle Body linkage Spacers and Shims
AMS Motorsports 300ZX Transparent Timing Cover Clear
OEM 300ZX (Z32) Timing Cover Bolt Washer
Z1 Motorsports 300ZX (Z32) Urethane Motor Mounts
Nissan OEM 300ZX Crank Key Z32, Z33, R35
AMS Motorsports 4 Piece Underdrive Pulley Kit - Nissan 300ZX 90-93 Z32
Gates Belt - Power Steering w/ 4pc UR V1 Pulley Set Z32
Clutch - Z1 Performance Street Clutch Kit with 6 Puck Ceramic disc
Flywheel - Z1 Forged 4140 Steel Light Weight Flywheel
Timing kit – Nissan
Water pump – Nissan
Gaskets and seals - Nissan
Haltech Elite 2500
Haltech Plug 'n' Play Adaptor Harness Kit
Z1 300ZX Alternator / Transmission Harness
Z1 Motorsports EFI Engine Wiring Harness 300ZX 5 Speed Manual 1990-95
  • 3 weeks later...
  • 1 month later...
Quick update, she is slowly coming back together. Installed the Quaife dif and half shafts from Kaiju (James Time Attack Z). Removed the  ABS system and ran all new, greatly simplified brake lines. Sanded the tint off the rear taillights, polished them and installed. Both doors fully reassembled. Roll bar installed. Pulled the fuel pump hanger and ordered a new walbro 255 pump kit. Wiring loom prepped and ready for install. Next up is dash rebuild and then prepping the motor for install.
Edited by madmarco
New brake line layout. Front straight to a T and then using the ABS sensor holes to reach the braided line coupling. One line running to rear into a T near the right rear wheel and then following the standard clamps to the left rear.
Edited by madmarco
The ABS layout does really overcomplicate the braking system on these cars. I’m not sure id want to do away with it on a car predominantly for the road but I understand your choice.
After installing R32 Brembos the ABS system was triggering too early. I pulled the fuse and drove without ABS on the road and track for many years without issue. In fact being able to brake at the limit allowed my NA to humble many more powerful cars. Removing at least 4 meters of plumbing can only be better!
I had the same, with the Evo brakes mine has up front, just too much front bias. I changed the rears as well to the same and it resolved the problem. If you are comfortable with it then that’s great, it’s your car after all.
Thanks Stephen, I hear you. I have Brembos on the rear also but it didn’t help.
