My daughter calls it Toothless the Dragon: My ‘95 TT Z
As with most projects and rebuilds, they all start in the same place, mine was no different. However, this isn’t truely the start of my forever ongoing Z project. I’ve owned this car (my second Z) since 2008 when I purchased it from a former member. For the first 5 or 6 years I did the usual mods with suspension parts and basic bolt ons. For reasons unknown, whilst running stock boost, piston 5 cracked a ring land during a track day at Castle Coombe. A forged build and a remap later all was well until a sunny October’s day 2013 at Bruntingthorpe killed that engine with what at the time was a suspected head gasket failure at 181mph..... And this is where I shall start my journal.
The Z was stored off the road from Oct 2013 until March 2015. I’d had a major knee operation at the beginning of 2015 which meant I was going to be off work for 6 months. I’d saved up enough to start thinking about a parts list to rebuild her and frankly, after a couple of months of staring at the same 4 walls, I was going stir crazy! I employed the help of a good friend and decided to pull the engine and see what was what.... just a head gasket my arse!
March 2015
Problem 1: It turns out stainless steel, exhaust wraps and condensation don’t mix well
Before I’d even got the engine out, a new set of downpipes was added to this list. These AMS items were only 2 years old, so I was far from impressed! I contacted the retailer and after a bit of tooing and froing I secured myself a set of replacements for free... how long they will last, only time will tell!
  • Replies 670
  • Views 101.8k
  • Hey all.   well I’m happy to say my engine saga is now pretty much behind me and I’m free to move on with my car!   So, what does the future hold…. Well I’ve pretty much got to start
  • After a bit of testing with various polishes and pads, we found that the Lake Country wool pads with Scholl Concepts S3+ followed by S20 Black on a meguairs polishing pad, then finished with S30+ on a
  • Over the last few months, a friend of mine and I have been undertaking the most thorough detailing work I’ve ever undertaken. Just over 70 hours of work have gone into my car, from 2500 and 3000g
Wow so sorry for you, what a horrendous nightmare, keep fighting they must not get away with bad workmanship.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
Thanks bud. If I can ask people to comment on the YouTube vid and share it so I can play the “algorithm game” and get maximum exposure, that would be massively appreciated!
  • 6 months later...
Well I’m happy to say I’m about to start the rebuild process of my engine!
im hoping to drop my block and internals off to my chosen machine shop in the next week or two (work permitting). Im scrapping the EPR block and starting again with a donor block I bought from Banzai Breakers months ago. Fortunately, as my billet main caps measured tighter than they should, there is sufficient material to be able to correct the oval and non-concentric issues with them to make them reusable.
So, the plan as it currently stands is to machine my donor block to 88mm for my CP pistons, remachine the billet mains, resurface the block faces, balance the replacement crank and rotating assembly. Then I can start the assembly process while I have my heavily worked heads resurfaced to a proper finish.
I will be assembling the engine myself. They one positive that has come from this while EPR saga is the knowledge I have gained about machining and engine assembly, meaning I’m very confident I can build a solid engine.
I won’t be reusing my GT525’s are they suffered too much damage from the bearing failure, so this time I’ll be using a set of Pulsar Gen 2 GTX2860’s. It became apparent during tuning that the GT525’s fell off a cliff at 6200rpm and meant I lost out on the performance my head and cam package should deliver. The 2860’s will easily flow what I need and very little sacrifice of spool, so it should be a more complete package that makes over 600hp with less effort.
In short….. positive updates coming soon… with pics
  • 1 month later...
After a bit of a delay due to work commitments, I’ve finally dropped my block off at OCS engineering to rework a donor block I sourced from Banzai Breaker a few years ago.
They’re confident they can make the needed adjustments to make sure the billet main caps fit properly and the correct size!
Can’t imagine it’ll be done this side of Xmas, but at least I’ve finally made a start!
  • 1 month later...
Happy to say my billet mains were salvageable and have been remachined to the correct size, and believe it or not, round!
Dropped off my torque plate on Friday so the cylinders can be rebored and honed and block deck can be resurfaced.
Happy that things are now actually progressing
First purchase for the Z in a looooong time. I thought while the engines out, I may was well replace the steering column bushing with a @gktech_official solid bushing. More new parts arriving soon!
Happy to say work on my engine block is now finished! Billet main caps were found to be up to 4 thou out of round. This time they have been machined using the ARP’s that will be used during assembly (unlike last time by EPR!)
Cylinders were rebored to suit my 88mm CP pistons and cross hatching angle, depth and surface finish all set up for the Total Seal gapless piston ring pack I have chosen to use. I think I’ll be the first person on the UK to use Total Seal’s gapless piston rings on a VG30, so I’m looking forward to seeing if the live up to the hype
  • 3 weeks later...
Well I got my block back from OCS last week and have started on the block prep for deep clean and assembly
first job was to clear the excessive casting flash in the centre coolant channel and smooth the entry point out. Out came the long shank tungsten carbide burrs. A small but positive improvement
Also spent a bit of time with the burrs to clear out the casting debris and stress risers from around the bottom of the block around the crank journals.
This casting debris is from the imperfect casting mould that leave small sections of iron/sand mix still attached to the main casting. In certain situations, harmonics can release bits of this debris which then has the potential to destroy the bearings, an engine, by being circulated by the oil system.
Stress risers are similar. They’re very fine ridges in the casting that can form a weak point. Simple remedy is grind them back flush.
After many hours research and consulting OCS, I decided to try something somewhat new with my piston rings.
I have decided to run Total Seal Gapless pistons rings. The setup includes a gapless top ring, with conventional second and oil control rings. To my knowledge I’m the only person in the UK to be running gapless rings on a VG30, but I know of at least one other in the states that have shown very positive results.
The term gapless is a bit of a misnomer. It’s a 2 piece ring, with their individual ring gaps rotated 180 degrees from each other, effectively making the area around the ring gapless. The positives include virtually 0 blowby (so a 0-1% leakdown vs 5% on a conventional ring), increased vacuum and reduced oil fuel dilution. The other benefit is you can run a larger ring gap on the 2 pieces, allowing the a wider margin for thermal expansion without the downside of increased blow by
The only real downside that I can see is the cost, at around 30% more than a CP Piston ring pack.
Hopefully this will help with slightly improving my idle vacuum (due to my cam profile) and a generally more efficient engine.
Edited by nickz32
I am very interested in these rings also, can you tell me where you purchased them from was it direct from the company? and what size diameter bore are they for, is your engine a standard 87mm? I have 88mm cylinder diameter bore
Regards Greg
Regards Greg
Bought them from Performance Unlimited. They’re the UK approved retailer.
88mm CP pistons. I had to give dimensions of rings as well as my anticipated power/boost pressure, that TS then matched to their products to spec the rings
Take some time off work this week, so enjoyed the day cleaning and degreasing a variety of parts.
Engine block is now ready for painting (hopefully paint will turn up tomorrow). Donor Crankshaft cleaned up really nicely, and pistons and rods are also ready to go.
Bloody love Bilt Hamber Surfex HD degreaser, by far best commercial degreaser on the market in my experience!
  • 1 month later...
Well after a 6 week intensive course with work, I’ve managed to collect my rotating assembly from OCS. All balanced up to 0.1gram.
Dropped my heads off to get a suitable surface finish (unlike the 127ra finish by EPR!) so they should be good to go in the next week or so.
Still waiting on block paint and freeze plugs to be delivered, then I can start the assembly process
Block prep is now finished. Primered and painted in VHT Cast Iron Grey and new freeze plugs installed.
Picking up a set of micrometers this eve to take post micropolish measurements of the crankshaft and then assembly can begin!
