Thursday picture game..
Evening guys, just a bit of fun, 23 zed items, name them and where they fit !!
Jeff
  • Replies 30
  • Views 1.8k
1. Coolant Temp ECU Sensor
2.
3. EGR Gasket
4. Manual Shifter Bushes
5. Window Roof trim clip
6. Aircon regas valve?
7. Idle control valve sensor
8. Door locking thing
9. Throttle cable mount?
10.
11.
12. Idle control valve connector
13. Fuses from Small engine fuse box. Fuel pump..etc
14. Crank Pulley Bolt
15.
16. **** knows
17. Plastic bumper clip
18. B-Pillar bolt cover
19.
20. Crank pulley woodruf key
21
22. Window regulator
23.
2.
3. EGR Gasket
10.
11.
15.
16. **** knows
19.
21
23.
Ooh some tricky ones there it seems, six of your answers are incorrect....
Jeff
Il try the ones Dave didn't get.
23. Interior trim retaining clip. Boot lid centre panel?
21. Spigot bearing
19. No idea
15. Gear box mount to body bolt
11. No idea
10. Hub nut
2. Drive shaft bolt, maybe a flywheel bolt.
Jeff
[ATTACH=CONFIG]102365[/ATTACH]
[ATTACH=CONFIG]102366[/ATTACH]
This is going to be bad but here's my go:
1 coolant temp sensor
2 cas bolts
3 balance bar gasket
4 shifter bushings
5 ?
6 ?
7 some other sensor
8 lock actuator
9 brake line retainer
10 ?
11 ?
12 coolant temp plug
13 fuel pump/interior power fuse
14 crank pulley bolt
15 ?
16 ?
17 ?
18 rear quarter interior bolt cover
19 ?
20 ?
21 wanruff key? Spelling?
22 door motor relay
23 interior trim retainer
Edited by Alic
21. Spigot bearing
19. No idea
11. No idea
10. Hub nut
Mmm... four answer`s incorrect..
Jeff
2 cas bolts
4 shifter bushings
5 ?
6 ?
7 some other sensor
8 lock actuator
10 ?
11 ?
15 ?
16 ?
17 ?
19 ?
20 ?
22 door motor relay
Mmm... nine answers incorrect there.
Jeff
and they are .............. ha ha i wont spoil the quiz :clap:
Good man ! kind of a busman`s holiday anyhow for you eh? lol
Jeff
Jeff
I need to get to work finishing this breaker then!
Before owning this car I knew nothing about them. I have owned it one month and have zero mechanic skills. I named 3 items, which for me was amazing. Just goes to show we spend more time under the bonnet than behind the wheel....
Plenty of time yet ! as far as zeds are concerned even I always say everyday is a learning day !
Jeff
One or two of them I recognise but just cannot place. Frustrating lol.
Lol !!
16. Targa end cap
Clever !! thought that one would fox most !
Jeff
Some tough ones - here's my attempt :
1 - Temp Sensor for ECU
2 - Brake Calliper Bolts
3 - EGR Plenum Gasket
4 - Shifter Bushing
5 - Roof trim clip
6 - recognise it but not sure
7 - Gearbox Neutral Switch
8 - Door Lock Cylinder Actuator Clip
9 - Brake Hose Clip
10 - Adaptor Nut for O2 Sensor
11 - Inside part of Water Thermostat ?
12 - AAC Connector
13. Fusible Links (small fuse box)
14 - Crank Pulley Bolt
15 - Oil Sump Plug
16 - Targa Panel Edging
17 - Targa Glass Bolt
18 - Looks like the screw covers for the plastics next to the rear seats near the top
19 - lock cylinder component ?
20 - 2x woodruff keys for the crank pulley
21 - Looks like the metal clips for the headlight casings
22 - Tail Light Sensor
23 - clip for something
4 - Shifter Bushing
5 - Roof trim clip
9 - Brake Hose Clip
12 - AAC Connector
15 - Oil Sump Plug
Good effort there !! best answer`s so far but 2 missing answer`s and four incorrect one`s
Jeff
I am never going to recognize these...........this quiz is biased towards over 90% of this club :taz:.
Keep them guesses coming guys, still some more to find !
Jeff
Give us a clue on the ones we have wrong then!
Ok hang on will switch to my pc..
Ok here we go..
2. ???????
3. EGR Gasket
5. Roof trim clip
6. ???????
7. gear box neutral switch
8. Door locking quadrants
9. Brake line secure clip
10. 02 sensor boss
11. ??????????
12. AAC connector
15. sump plug
16. Targa end trim
17. Targa through glass bolt
19. ??????????
21 Crank spigot bush
22. ?????????
23. ?????????
Edited by JeffTT
2 front water pipe bolts
22 rear light relay / box of trick behind the OS rear boot panel.
23 cruise control cable retainer ??
Edited by Iangreenfield
2 No
22 Yes
23 No
Nice call on the light relay box, looks very similar to the window amp one, the rest no
Jeff
