JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 132.6k
  • And they have arrived !
Looks like my zed has no spark and that's why it wont start.
I think I've tested correctly but to be honest not even sure on that at the moment.
After removing a coil-pack along with its associated spark plug i held it against the plenum to check for spark and get nothing.
Tried with a few other coil packs and get no spark from them either.
Its a brand new loom so was thinking i've missed something or maybe i've a blown PTU, Relay or fuse.
Any diagnostic’s you can run.
2004 BMW Z4 30i
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
That and check continuity between the ECU side pins for spark and the PTU end - has it run before with the new loom? Unlikely all 6 wires are failed but you never know I guess. You could then check the wires out of the PTU when cranking with the fuel pump relay pulled. Check your coil grounding too.
Either way - not sure whats available on the Link but a stock ECU might give you easier diagnostics via Datascan/Conzult. Hopefully you can resell it for whatever you pay too.
Good luck mate.
So for anyone who hasn't seen my facebook posts today my little mapping trip didn't go to plan - again.
However i haven't came away with complete bad news as with the assistance of DynaTune we diagnosed the issue.
It turns out my new loom has permanent voltage going to injector plug 6 which in turn floods that cylinder.
Bummer, as its a brand new loom from wiring specialties.
Good news is we didn't flood it before this was noticed and we now know exactly where to put attention on next to fix the issue.
To test the injector harness we used this little glow plug which cam in handy.
Why does shit like this always happen to me.
Wiring Specialties have royally screwed the build of the loom and mixed up the pinout to Injector 6.
Tracing it back i get the Injector Socket 6 (Pin 1) going to Pin 115 on the ECU which is for the 'O2 Sensor Ground'
The correct port should be 114 according to the ECU pin guide below.
Getting 12v coming in on pin 115 also scares me as that says it a ground connection.
I have emailed the manufacturer to see what they say but i think the full loom needs to be sent back to be fixed.
That sucks. Shame the luck you have had.  If you wanted to avoid the delay of sending it all back - you should be able to re-pin the connector to the ECU and switch around any incorrect pins if you have the right pick/tool. You'd probably want to trace and test almost everything though... but might be better than pulling the loom, waiting and then reinstalling.
Think we misunderstood eachother. I thought you were saying you were pondering removing the loom completely.
I was suggesting what you just said.
I heartily recommend Chris@Dynatune, he is very knowledgeable about Zeds, he's got mine running like a wee sweetie 😊
  • 3 weeks later...
