JaiKai - MK2 - Ziggy Build
  • Replies 1.2k
  • Views 125.9k
  • And they have arrived !
54 minutes ago, Stephen said:
I can’t remember so best check with someone who does know but I think the Forged pistons sit a little sloppier in the block with bigger ring gaps.
You may find the shop can resurface the bores to take out that score, obviously this depends on the depth of the scratch and you will just have a slightly larger ring to accommodate. You might be within tolerance, if your lucky. This would also depend on what happened to the bores last time.
Going to order new pistons and rods so going up a notch isnt that bad.
The current pistons i'm going to write off or sell to anyone who wants them cheap.
Just caught up on this thread as I haven't been on the forum in a while and I had to find out why you were rebuilding again! Your perserverance is just insane, but you're going to be bored out of your mind once it's finished!
4 hours ago, JaiKai said:
I had a wee surprise delivery from a Fedex van today and honestly wasn't expecting this for another week.
Ordered from concept last week for my engine rebuild.
Only thing that is missing is new pistons and rods; which after i get the bottom end checked, cleaned and honed i will look at.
Cool - great news Lee.... :-)
1 hour ago, Chris said:
Just caught up on this thread as I haven't been on the forum in a while and I had to find out why you were rebuilding again! Your perseverance is just insane, but you're going to be bored out of your mind once it's finished!
I was a twat when i built the last one - again.
When I transplanted the polished plenum from the previous build i didnt check inside it thoroughly.
It contained fragments of the previous blown engine when then got sucked into the new build.
Both me and phutumsch had FedEx deliveries from Concept z really quick and well before the delivery due date over these past few weeks. Had mine delivered Tuesday this week. Took 5 days longer to get a Royal Mail delivery from Northampton to Brighton ffs [emoji1787].
Looking good and good luck with the works.
There is a dead give-away to your location in this picture...
19 hours ago, JaiKai said:
Just dropped off my engine block and crank at an engineering works.
Cylinders to be honed out and then full think to be stripped in a hot bath.
Also sent the sump to be stripped and repainted black too.
Is that expensive? I would like to have a go at rebuilding an engine one day. Im getting more confident at doing things myself and doing a complete engine with upgraded parts does seem like fun...
Was quoted about £250 to dip the block, hoan the cylinders and and polish the crank.
Oil Cooler and Water radiator now ordered too.
Progress is looking good [emoji1417] Which brand oil cooler did you end up going for and where did you source it from?
