Few upgrades for next year. Thoughts?
I just want more damn power! Having been fortunate enough to drive some HUGE hp Z32s (850hp being the most powerful), I've decided I just can't handle 1bar and most have more!
I'm going to be pushing the stock motor a little, but I'm confident it can take it if done correctly. Jimmer rebuilt me a fine engine a decade ago and I'm keen to see how drivable it will be with the correct modifications.
I've gotten to the point where everything else has been upgraded except the clutch, so with the exhaust, Brembo brakes, single piece prop and the general amazing health of the engine and turbos, it's time to do something a little more.
The plan is 555 injectors, Profec B, 2.5" intake, possibly a Selin Translator and a MUCH better clutch and a full day rolling road tune with a Nistune board I hope to get close 400hp although I'm not chasing power figures, drivability is first and foremost so response and turbo spool are what I'm more interested in. Whilst that won't seem like much to sum, I am keen to retain drivability and see how good the stock block and heads actually are. Have also considered the JWT cams and I think I can get a good reliable figure. A good map is key and I've found someone good to do it.
I will most likely need RLTC just for safety.
If it doesn't last, Power Enterprise turbos and some better pistons will be bought.
  • Replies 36
  • Views 3.3k
Well that was... unexpected.
Are you sure about the cams? The *racing cams in Ash's car made it quite lumpy at idle. Well not lumpy but not smooth either.
I've been wanting more power for a while. There are 2 different profiles that JWT do, I'd get the mild versions if I were to go that route.
I'd like to see the results anyway. Did i read somewhere that the stock tb22s max out at about 16psi?
Edited by Alic
No, they can take a little more. 18/19psi and they run out of puff. The stock engine's most limiting factors are their breathing and low flow injectors. Nissan de-tuned these engines quite a bit by restricting airflow and fuel.
i've jwt R5 "race" cams, overkill for you, "Mild" is definatly best for you,
2.5" pipework is good, but can be a bit messy, may lose your oem look under the bonnet.
modernising the power of the zed to bring it in line with its newer rivals, logical step for OEM+
Is that intake cams only?
Good luck with the extra power Si its nice to have more BHP without going overboard and killing the engine or the Z. I think I'm happy with my 350bhp and will just concentrate on its looks but more power is all that is left for you to do now so hope all goes well and look forward to the updates mate. :thumbup1:
Stuff the bhp, shoot for torque. Here's where you start; 2.5" intake pipework, planer kit, dual maf, msp manifolds, 3"dp and 3"-2.5" decat.
and 2.5" SMICs.
GregD@SZ "I am here to tell you that IN MY OPINION it would be better to upgrade your intercoolers and pipes rather than upgrade your
turbos if your not going to do both." and "Manifolds are a must as they are too small for stock turbos."
http://www.twinturbo.net/nissan/300zx/forums/general/view/2415470/A-little-info-about-turbos-and-pipes-DYNO-CHARTS.html
Yeah, I have Z1 intercoolers. I think (know) the stock engine was over engineered to a certain potential and I just want to unlock what was the restrictions given to it.
I'll draw the line at MSP fannymoulds unless I change the turbos at a later point.
No, they can take a little more. 18/19psi and they run out of puff..
Eek !!! dangerous territory there Si, you will have that tuner guy..... erm..... damn forgot his name, lives in Nania or somwhere, anyhow telling you that you know nothing and he can get 500 bhp out of a standard engine..... yep really, honest, its real :clap:
Jeff
Edited by JeffTT
My tuning advice on stock engines comes from Los Angeles, not from Leicester. :lol:
Nania dear boy Nania :biggrin:
Jeff
Very interested in how all this all comes together Simon.
Out of interest, where does head porting sit within the enhancement of intake improvements? and exhaust come to think of it.
Or is that kind of modification old hat now?
What do the Americans know about tuning these cars. The stock block is only good for 350bhp and only 280 with a series 1 ptu.
what do the americans know about tuning these cars. The stock block is only good for 350bhp and only 280 with a series 1 ptu.
s***
Other than reliability what is wrong with the S1 ptu?
My car was sold as '400hp' which is just a load of *****cks, just with the decat, intercoolers and the ecu I reckon i could get close. But don't really want to until i see what injectors its got in it.
Edited by Alic
Certainly not old hat. Good head work is money in the bank tuning wise.
s***
Hmmm not sure I said that lol
Although I have a suspicion that there is a beast beneath when its sorted mate
s***
Sarcasm unit at factor 50 youngen. Just fyi mine makes 370+bhp @ the fly dyno proven nice and safely on stock tubs and injectors.
and 2.5" SMICs.
Ah yes that too! My intention was to have a specialist replace the 2" outlets on my Greddy coolers with 2.5". Assuming the cost is less than me selling them and buying a new set. Possibly an option for you too Simon?
Perhaps that was bad wording on my part. You said 'the chap before me claimed it was running 400'
I think the manual box that's going in it will make it seem faster, at last more responsive as the auto box(s) were slipping lots. After that all I'm going to install is the boost controller and up boost to 9-12-14, whatever I can do say without leaning out.
So something like 330whp? In a way I want to see how much I can make with the current setup, but will install a wideband first, the last thing I want is to go blowing stuff up.
Edited by Alic
