So, my 99 spec bumper is in the paint shop and so I now want to get a new bumper plate for it.
So, do I go UK and horizontal rectangular or import square style? Which suits the 99 spec best in people's opinion?
The car is an import so its square import style on the rear. Also, the reg of the car is an Irish style one.
Anyone got any photos of their 99 spec bumpers with plates on they can show to help?
  • Replies 27
  • Views 3.8k
I personally like using a standard front uk size plate made up using the same size lettering as used on the rear jap size plate which is a narrower stroke size and smaller spacing, then trim the entire plate down leaving a small margin around all 4 sides, totally legal and looks just right to me.
Shame we need a plate at all really though.
I changed mine from square to a 3/4 import plate.
[ATTACH=CONFIG]93235[/ATTACH]
[ATTACH=CONFIG]93236[/ATTACH]
I think the square plate makes the car look as though it's trying to eat a Granny Smith through a letterbox. Nice change :thumbup1:
How do you mean "Irish style"? I think rectangular looks better on the front but ideally a smaller one like Ian posted.
The smaller 3/4 one overhangs about 1/2" each side of the mount on the bumper a std long plate overhangs way more and doesn't look right imo
Totally agree
Defo small plate !!
Jeff
Edited by JeffTT
Wow, so many styles, but all going in the same direction - smaller. So what is the smallest legally we can go?
We can run on smaller plates as the vehicle isn't type approved
Character stroke is 10mm
Character height is 64mm
Character width is 44mm
Character spacing is 10mm
Group spacing is 30mm
And a 5mm margin on all sides
So actual plate size isn't specified a shorter reg would equal a smaller plate, stick to the above and your legal.
Thanks, I need to change mine and this is just what I'm after.
Can anyone recommend a decent online supplier, or is it best to just go to someone local?
Basically u won't find a plate that overall size, but get a standard uk front plate made with the smaller lettering and correct spacing then trim the plate with a 5mm margin, polish the edges using wet and dry and put a nice radius on the corners and voila. :biggrin:
I got my 3/4 plate from fancy plates.com no need to cut polish or anything just stick it on they even supply the 3M sticky tape with the plate.
I prefer smaller plates
I ordered that one from fancyplates.com when I bought that private reg. Was 3/4 size.
Just went to buy one for my current zed and they want £20!! So i'm trying an ebay seller instead for £10.99.
But in this case I'm happy to admit yours is bigger than mine :w00t:
Where did you read the group spacing of 30mm? The 5mm margin needs to be on the top and sides, on the bottom it's 13mm.
