- Replies 54
- Views 5.6k
- Created
- Last Reply
MasterCookieman 23 posts
mantav8 5 posts
Funkysi 4 posts
groover 3 posts
Ok, I'm painting my car with cellulose paint next month, in a gazebo - everything as usual on a strict budget...
My Zed is primed and rubbed down, and ready for the base coat. I've been praticing on other parts - nose panel, targa stips, door handles etc. I'm getting the hang of spraying, finding it annoying how every little imperfection shows up with the base coat - why can I still see score marks from sanding, even after rubbing down the primer with 600 grit?!
I don't plan to use clear coat, due to the extra cost, and the added risk of screwing up at the end. It should also be easier to respray anything I'm unhappy with at the end.
The paint I'm using is this, which dries glossy -
http://www.ebay.co.uk/itm/1L-Mystery-Purple-Cellulose-Metallic-Gloss-Car-Paint-Custom-Colour-Celly-/330405867444?hash=item4cedb96fb4
Now, I understand, from all my research, that I'm meant to rub down my finished paint with 1200 / 1400 grit, then use a cutting compund / paste to eliminate the scratches, polishing to a glossy finish. I've tried this on the targa end strips and it just leaves dull finish, the other freshly painted untouched targa strip looks way better. So why do I need to use a cutting compund, it looks fine the way it is. Can't I just seal the fresh paint with wax? If I has orange peel I could understand, but it's already a smooth finish.
Any advice would be great.
