62mm Billet Throttle Bodies
These bad boys turned up this week from the States - 62mm billet throttle bodies designed and manufactured by Robert Bastian.
They are fully CNC machined from billet aluminium and are beautifully made. They have proper shaft seals (no leaks under boost)
and the butterflies are a perfect fit when closed. They need the return springs and stops transferred from OEM throttle bodies and
the intake manifold will need porting to the larger 62mm bore. They will be installed along with AshSpec SMICs and 2.5" IC pipe
work in due course.
Held up to bright lighting:
By way of illustration, this photo shows another car with the 62mm throttle bodies fitted (along with AshSpec IC pipe work):
  • Replies 26
  • Views 8.3k
  • The first run was done many years ago which I bought from. There was a second RobZ run planned which Aff68 on here was involved in but I don't know what became of that. Polar engineering in the US are
  • As @AndrewG stated, I persuaded Robert Bastian to run a batch, after months of getting enought interest / commitment for a group by, and all were sold. However, these do come up for sale from time to
Very nice Andrew, all most a shame to fit them to the car, lol
  • 6 months later...
Andy, now you've been running these for a while, any feedback?
They're still in his garage on the workbench! :lol:
  • 7 months later...
i would like a set of them to. were are they listed for sale
sorry just found the gaskets. i know its best t0 ugrade all the pipe work to 2.5, but is that a way of keep the stock pipe work for now and just changing the the 2 top throttle body pipes ? so you can use the bigger throttle body with the oem pipe work
You will need to transfer the spindle parts from stock throttle bodies (plus the new replacement parts that come with
the kit from CZP). Picture below shows what's involved.
You will need to remove the plenum material you can see in the picture to match the new 62mm diameter.
There is really no benefit in having 62mm TB's with stock pipework as they are the finishing elements to a complete
2.5" intake system and 2.5" IC's.
Edited by AndrewG
[ATTACH=CONFIG]98616[/ATTACH]
[ATTACH=CONFIG]98617[/ATTACH]
my manifold is coming off next week so am thinking should i uprade to 2.5 while its all off. are you using duel maff set up with this ?
the manifold am using is already off as its getting powder coated as we speak the then removing the one on the car for the powder coated one, but am thinking the would it be easy to fit the bigger piping when the manifold if off ? the cars in paint so the bumpers of to will see how am fixed for cash mite just upgrade the lot now while its in bits
  • 8 years later...
Polar engineering in the US are/were also making their version:
https://www.polarengineering.co/product-page/nissan-z32-300zx-billet-throttle-bodies-62mm
Edited by AndrewG
