Now with the size of our engine bay ....
OK, if it's a "1.5-liter turbocharged three-cylinder engine called DIG-T R that puts out 400 hp", what's 3 x 2 and 1.5 x 2 and 400 x 2? Put 2 of'em on the same crank and should be 3l V6 with 800hp. What other car runs a 3l V6 ?:dots:
Yeah 3cyl engines always sound great... There was a 1L or 1.5L cosworth that made 1000hp at 12000rpm, it was a mid 90s block Si hardly new.
I'll take two thanks.......
....And there's the reason why....:biggrin:
so how often does it need rebuilding?... hmmmmm
Well it'll be running at Le Mans this year, so hopefully less than once every 24 hours running !
I particularly like its Exhaust system and the custom press moulded specialist heat shielding thats going on it.......rumour has it that whoever designed those bits is a genius...and really good looking.......and amazing in bed :whistling:
Edited by Yowser
