Right, Noel (Turbonoz) has had my car for the last week and has set it up properly. He's installed some colder plugs, fixed a couple of boost leaks and a small fuel leak, produced a new custom map and setup my Profec B spec II. Many thanks to him for his patience and professionalism
So, any guesses? :) Relevant spec is as follows...
UK 1993 Nissan 300ZX Twin Turbo
Manual 5 Speed box
Donor TT block (from a UK auto)
GT600R Turbo Kit
NISMO 555 Injectors
A'pexi Twin Induction (single MAF)
A'pexi BOVs
SGP Lightened Underdrive Pulley
New PCV Valves and Hoses
New Injector Connectors
New Coilpack Connectors
Koyo Racing Radiator
Smithy SS Fuel Line Kit
Greddy Side Mount Intercoolers
AIVs Removed
Carbon Canister Removed
RPS Twin turbo MAX Street Clutch
RPS Aluminum Flywheel
Edge Racing Stainless Steel Testpipes (2.4")
Mike Smith Manifolds
New Detonation Sensor
EGR Elimination Kit
Ramey Z 300ZX Heavy Duty Idler Studs
Z1 Ultimate VG30DETT rebuild kit
Cometic head gasket
Z1 "5 bolt" Stainless Steel Downpipes
New PCV system kit
New O2 sensors
Temporary straight through exhaust (cats removed)
Greddy Profec B Spec II boost controller
Last tested on stock tubs and injectors:
304.9 rwhp @ 5394rpm
313.5 lb/ft @ 4796rpm
So please guess away - be interested in what you think it comes back with...
CheersZ
Steve :)
Edit: closest guess earns some rep and a pint :D
Edited by cybernet
'93 UK TT Manual
  • Replies 56
  • Views 2.2k
He's doing mine on the 17th June but I only have stock internals but everything else.
My guess is you'll reach 600bhp :wink:.
Edited by phutumsch
The way I see it is if Noel can get 450 bhp out of a stock auto then this engine should piss all over 500 bhp, it just depends on how much you told him to push it Steve ;-)
I've asked for "driveable but not mental" Gaz ;)
'93 UK TT Manual
Nice edit!! So original guess is 500 ;-)
You have been a busy boy, Steve. I say 525.
LOL - most of the parts for the rebuild were purchased in 2008 bud - it's taken a while to get here! ;)
'93 UK TT Manual
Is yours the grey one mate? 99 spec front bumper?
That's the one Lee - I need to update my garage at some point with spec and pics..
'93 UK TT Manual
i will say 583 with clutch being the limiting factor :) as i think it will start to slip after that figure
good luck
Bloody hell Steve - nice build!
Im going for 575 with more to go on one of his more aggressive maps!
Come on do tell !!!!!!!!
Haven't got a graph or the exact figures yet Gaz - I'm away from tomorrow, and will be picking her up on Weds.. Looking forward to the drive back if all's well :D
'93 UK TT Manual
