Engine Build Take 2 Plus CPZ Order
Been saving up for my next engine upgrade
Going to be Proper Power now :)
Emerald After Market ECU ( Got )
90mm Wiseco pistons $750
90mm Cometic HG $166
JWT 500's Cams $920
BDE VTC Pulley $445
BDE EX Pulley $365
2.5" inter cooler pipe set *
Side Mount Inter cooler's * $1500
Larger throttle body's *
Clear timing belt covers $195
Surcharge $150
Postal $245
Total $4736 = £2928.69 A fooking lot
plus import duty's
Plus another £200 quid for Engine work
Is any other person needing items from cpz in a few weeks time ?
Edited by MarkDerby
  • Replies 298
  • Views 13.7k
thanks noz well your handy work was spot on .. started first time as u see on the video :)
Just looked at the video and it looks stunning and sounds sooooo nice..... Sorry haven't heard mine running for 6 years and now dribbling over the sound......lol
Just going to look at post 185 for the breather.....lol
very nice mark cheers for the vid, bet your itching to get those first few thousand miles out the way and make that first pull.
indeed its just nice starting it up and hearing it
exhaust is built and should be on its way :)
Just had a look through the full thread.
Great work and sounds lovely.
You will be delighted once it is all setup and running, then you can get it out a blast and tear up the tarmac.
yeah far as i'm aware ... it was Rev 1 that was wrong ... these are Rev 2
TBH i can not tell you what the Problems was with Rev 1 and these compared but up to now the quality looks spot on
no air leaks and the fitment of the throttle flaps was spot on no stickiness or wobble
and the car idles ok too
Great work mate, glad to see you've finally got it running - just the mapping to do i guess now and fingers crossed you have some better luck with this one. Look forward to seeing it out on the road :)
just check my tracking number and my exhaust will be here on friday .. fooking excited :):)
What's the exhaust you're having made Mark? Dirty great big twin 4" straight through I hope
5" .. haha
all most the same as this ... from labree
Z1PG3IN112912WTPTZb-ee0c7d27.jpg&w=800&h=600&page=popup
Edited by MarkDerby
