Engine tansplant. Help needed!
I am looking for people to help me with my engine transplant. Although i am quite handy with the spanners, this is unfamiliar ground for me! I could really use anybody that has experience removing the engine from the 300zx. Even if you havnt done this before the more people i have helping the better!
I have use of a 2 post lift plus any tools i require for two days, Saturday 3rd & Sunday 4th November. I can be there from 9am till as late as i need. This is a link to where i will be going, Ramp and Wrench
Please Please Please, if anybody can come down and help on either or both days, even for just a couple of hours, it would be very much appreciated! I really need to save my Zed and i cant do it alone. I would even be willing to pick people up and take them home to save there own petrol!!
  • Replies 68
  • Views 4k
we are going to pull the engine with Box still on it ...
its to much of a Faff to Mate the engine to box when its free standing
Last time when i instal engine in my 300ZX it takes me 3 days (yep, days) to install gearbox on my own without special tools ( https://picasaweb.google.com/lh/photo/1rEuM77M0c9KTsIoI5kG1dMTjNZETYmyPJy0liipFm0?feat=directlink ). Its REALLY pain in the a$$, its the worst part in my opinion... This time i try to remove and put back my engine witch a gear box on it.
I see, does that still apply for an automatic ( I have TT auto)
Yep indeed just the same
alot easier if your doing it by your self ...
but its each to there own on this really
Going to be a good weekends work. Quite looking forward to it :) I'm praying all goes well!
Oh Mark, i've been meaning to ask you, would you be able to write me a receipt for the engine? Just for my service history thats all, so i have something to back it up should i ever (i never will) sell her.
i took the engine out and left my auto box in but ime going to put the motor back in with the box on it for a few reasons but the main one being i dont want to risk damaging the T/C oil seal..
Edited by znut
Today's the day! Would like to thank anyone who has said they will come and help, and the door is very much still open if anyone else would like to come :)
And? Any good news :) ? Its possible to remove engine with a gearbox?
Yes m8 it is .. did say in post 27/30
Manual/Auto Box and engine can be removed and fitted
Just want to say a MASSIVE thank you to Neil, Dave and Mark for coming to help this weekend! I honestly couldnt have got even half of the work done without your help and experience.
Thank you Thank you Thank you Thank you!!
One minor hiccup with a manifold gasket, but we'll get there eventually :)
no worries Rob, dont forget to upload the million pictures i kept nagging you about taking . they will help other for sure .
Sayers
Wont be tonight, i'm off out to enjoy my last night off work in a minute. But will try my best to post them tomorrow :)
I was glad to be of some help, only wish I could of done more.
Good luck with the rest of the rebuild.
Please keep the updates coming.
Not at the Mo i'm not sure what rob has taken but the car is now in my garage
ready to take the engine back out tomorrow
some how a manifold gasket as not been located right or not fitted so it has to be sorted :(
You didnt use a spurious gasket set did you mark ? Oem is always the way.dont use the ams manifold gaskets that come with the manifolds either.very poor quality imho.
ehh i want to take out my engine tomorrow too, thats why i need some -How To- ;)
Jimmer there OEM gaskets but got a feeling its just not been put on right
u know how that can go on two ways but holes will not align up
Drain Water
Take batt off
Engine cover & Balance bar off
wires / plugs off Coil up and pace in to battery compartment
Undo Earth strap from bulk head
Soft boost pipes
side metal boost pipes
plastic intake pipes
rad out
Aux Belts off
Fan off
Viscus unit off
AC Pump unbolt and hang down
PS Pump off and hang down
Alternator take completely off
Jack car up Put on Car sands / ramps on all 4 corners about 12" high
Take of the Exhaust system from Turbo elbows
Gear box
Manual* 4 bolts that hold the Gear support arm on to the box
Manual* long bolt that connects the gear leaver linkage
4 bolts in the middle of the prop shaft But Mark there Position
Undo the Center bearing
Support the engine with a trolley jack
Undo the 6 bolts on rear gear box mount
disconnect all wires going to box
Starter motor off
Manual* .. undo slave cylinder "do not take of the pipe work"
Auto* disconnect gear selector arms
back to the engine
undo the engine mounts from the sub frame
Undo the Steering Universal joint
Loosen the 4 bolts holding the sub frame by 1/2">3/4"
Take off the Oil Cooler pipes that run beside chassis rail
Back to the front of the car
Take Bumper off
if you have a front mounted inter cooler take that off too
Air filter and Maf unit
Now when taking the engine out u strap it to the very 4 front of the plenum intakes
u may want to drain the oil out of the Gear box or leave the front half of the prop shaft in the box
bit of a quick run down i may of missed a 1 or 2 things
started at 5pm today .. engine is now out on the stand at half 7 ..
we can see the middle gasket on the manifold has not been located correctly so hes just not in the progress of taking the tub of
to rectify the problem
Thanks for the update Mark.
Hope all goes well with the reinstall.
