Bent ! ..... and to say thanks to ( Sayers - Neil )
Well as most of you know not had a good time with my car ... and had to take my engine out again due to a brand New turbo failing ..
And a big Thank you to ( Sayers ) Neil coming around today to led me a hand in taking the engine out for a 3rd time in less than a year ... m8 thanks very much your help was appreciated loads and if i can return the fava in any way i will :)
any-who found out why my turbo had failed .... Bent Shaft and nackered bearing
heres a video of the tub and some Pics of it installed
as you can see all oil/water/return are spot on and no kinks and free flowing
disconnected oil lines and 100% oil even to the point there was fresh oil inside the turbine side behind the fan
so will be speaking to them tomorrow morning and hopefully taking a trip over and get it repaired there and then
Mark
  • Replies 28
  • Views 942
you dont expect that from new do you :(
Good job you can do the work yourself. other wise it would of cost mega bucks to sort it out again.
its not the point tho .. i still have to find time to do it and that cost's ££££
Need New
Oil Filter
5lt Oil
Gaskets for turbos
Borrowed engine lift
Neil's Time and Fuel
My Time and Disappointment
Missing a big'sh Show
.. so yeah should be something there for me
PRICELESS - for everything else there mastercard !
Total bumber doing all that work for something that new and then to find is busted.
Need New
Oil Filter
5lt Oil
Gaskets for turbos
thats terrible :(
You should definately screw them over for your time and effort. They want to be replacing it and refunding you the price of one turbo to cover your costs.
had some Emails from them all ready
Old'st at bottem ... new at top
Hi Mark,
Unfortunately we do not cover any costs incurred from removal/re-fitting/additonal parts etc. Our warranty is exactly that, a warranty. It is not insurance against other costs (I know this sounds blunt, but easier for us to be on the same page!).
With regards to warranty, nothing is decided or finalised until the turbochargers have been fully inspected. The shaft bending may of course be down to imperfections in the turbine shaft, but there also many other reasons why this may occur.
I'm off to the airport now, and won't have access to my emails until wedsnesday, but please feel free to get in touch with my colleagues (Matt Waterman is technical team leader and will be up to date with this tomorrow).
Regards,
Tom
Sent from my iPad
On 9 Apr 2012, at 17:53, "Mark " wrote:
yeah thats fine .. will speak tomorrow morning and check if they have core on shelf ... and i have the . paper work ....
i know this is warrantie as the shaft shouldnt of bent line that or bent from new
to be truthful thats the tub i dint bother spinning as it was the 2nd one fitted
now the other problem i have is the cost of items to refit it ..
new gaskets,oil,filter,time ... how do we stand on this .. as if it was a garage doing the work
the cost’s would be mega and that would have to be sorted out .. its not as simple as taking the tub off the hole engine has to come out .... thats the bug bare with it
its taken me a full day just to get at the tub
Mark
Sent: Monday, April 09, 2012 5:58 PM
To: Mark
Cc: sales
Subject: Re: FAO Tom GT2560rs Mr Kent ( derbymodelshop )
Hi Mark,
You can bring the turbos down for one of the technical team to give them the once over, but they will need to follow normal procedure and be properly inspected. I cannot confirm whether we have another Gt2860 on the shelf either - this will have to be checked tomorrow. My colleagues will be receiving these emails so they will be up to date. Remember the warranty form I sent will also need to accompany the turbos.
Regards,
Tom
they will probably try to weasel out of it, sorry to hear it, makes me kinda nervous as my zeds getting it turbo's changed by a garage next month...
sorry its off topic but where did you get your braided oil feeds from?
i cant see how that would have left the factory like that thats a serious quality control issue so must have failed after. i dunnow hat could have caused it overheating? forgin object but im damn sure its not cool.
god knows ... i think its down to incorrect temping of the shaft when it was made ... and with the heat of the turbo ... well as u see it bent
if it was something that was ingested they would be impeller/compressor damage to the majority of the blades
the only damage is to the very outer edge tips where its been touching the housing due to the wobble
the Tubs came from the Turbo Dynamics in UK ...
all my fitting kit came from Z1 for the same tubs
i'm hoping to take them tomorrow and get it sorted there and then
was a saving of around £700 doing it this way but wasnt expecting it to fail
luck'y i'm doing the work my self ...
Sorry to hear that Mark.....
.....and without sounding negative (I'm just playing devil's advocate), if you buy parts from somewhere and then get them fitted elsewhere (or DIY) then if those parts fail, the supplier is only obliged to replace faulty parts and is not responsible for any associated labour. As a businessman myself I excercise the same policy for lift components (if one of my own engineers does the work, it is a different matter of course....).
You sound aware of the situation anyway mate; and I hope you get things sorted with little inconvenience to yourself - plus if you push the point the supplier might even offer some goodwill towards your consequential costs.
Good luck Mark,
Richard:flowers:
Well I'm Back from Dorset with a new turbo .... none warrantied like my gut feeling all along ... after inspecting the turbo it failed due to Oil starvation
they found and showed me Rubber/silicone item with in the Oil re-stricter
where this came from not sure ... not sure if it was from the braided lines or from old Oil fittings
so i'm another £450 quid lighter
so tomorrows job is get the engine back in :)
sad ending for you,this is one of the reasons Shell engineers banned silicon instant gasket paste and the like because it breaks off and clogs the oilways.
That is a bummer mate but glad to see you're still moving forward. Have a good look around for any other sources of silicon debris before it goes back in. If there was one piece there could easily be more
On the other hand though, be thankful you didn't buy your turbo's from a company in the US as many do. Can you imagine the ball ache, cost of sending back to said company, they send back to their turbo company, your 1000's of miles away and it comes back no fault of turbo, you have to buy another and have it shipped back. Time wise in total say 3 weeks plus?
I was previously an authorised supplier of TD turbo's and had a very similar problem with a customer, TD with their very expensive and vast equipment will show pretty much why it failed and with new turbo's from most companies, 99% of the time it's either fitting or previous engine fault. In this case the garage Option motorsport admitted not checking oil pressure and non contamination before the oil feeds thus destroying one of the new turbo's. Something you really should do before fitting new turbo's on any car to ensure future reliability.
Good luck and hope it all finally pans out for yer fella!
Smithy
yeah it was all fresh oil,filters before tubs was fitted ...
now on the other hand ... the garage that repaired it some time in its life when it had new tub fitted
used silicone this was used on the oil fittings around the engine
i did clean it all off ... well i thought i did but guess not :(
Well anyways its back on the rd as from today dont think i did bad i started at 10:30 and finished around 6 ...
thats getting all tubs back on engine/gearbox and all u know that goes putting it back
well happy now lets hope this is the last of it ..... :)
shoulda let us know you were coming down to my county woulda put the flags out.
sorry to hear it wasnt warranty mark :(
but great work getting it back in today! you dont hang around!! :thumbup:
It was the only day I had ... But glad its running ... For how long who knows .. its a zed after all
Hope you can finally start enjoying it now mate. You have put so much time and effort into it, it's about time. :rockon:
Smithy
Smithy do you check the oil pressure on the oil return from turbo to sump? How would you plumb a gauge in, is it a case of fitting a sender/12v supply/gauge as if setup in car?
There isn't a pressured oil return on tubs its an oil drain that runs back in to the sump directly ...
