What aftermarket guages do have?
c'mon... spill the beans.
What guages have you added? what do they monitor? what do they look like? where did you fit them?
greddy oil temp,oil pressure and water temp and i have a single autometer for boost
Edited by znut
Defi gauges (water temp, boost, oil temp) fitted because stock gauges are shite
Autometer oil pressure,Autometer water temp mounted on the pillar.
Tim turbo gauge, glowshift Air fuel/Volt gauge and glowshift oil temp gauge
all in the DIN slot above stereo
F&F :smw: but ultimately will be looking for a better make.
water temp, boost and oil pressure (not hooked up as havent got sender!) in A-pillar pods
As above with oil pressure and boost and 2x AEM wideband guages mounted in the A piller.
AC Autotechnic S7 Invision Boost, Temp and Voltmeter. Wiring a doddle with the feed taken from the clock, extra coolant sender fitted to aftermarket top rad hose. Gauges awsome at night but sunny days they can be hard to see.
Cheers John
Cheers John
I have the exact same as these. But oil pressure, water temp and boost.
Swoosh: Oil pressure, Oil temp, water temp in a pillar pod
vbpgimage.php?do=full&p=1500&d=1206113681
Edited by bantambunny
john how much do these guages cost and where do i get them from at the best price ??
Rob
Rob
I bought mine from a Forum member a few years ago but there was an oil press gauge there as well. I ended up buying a voltmeter from http://www.flat4online.co.uk but from the link below they are quite expensive now. I think I paid £50 for the Voltmeter.
http://www.flat4online.co.uk/catalog/advanced_search_result.php?keywords=AC+Autotechnic&search_in_description=1&inc_subcat=1
Cheers John
Apexi EL Gauges, water temp, EGTand Boost all in A-pillar pod and an electronic AFR under dash.
Smithy
Pro-sport Oil pressure and temp + Water temp mounted in a triple A pillar pod
I have autometer gauges. Water temp, Oil temp, Boost, Volts, Air-fuel ratio and Oil Pressure:shock:
In centre DIN=boost-water temp-volt-oil pressure/ on A pillar oil temp-innovate wideband afr and last but not least fuel pressure gauge on the pillar also
water temp, boost, oil pressure
