Paul@SWZ
Everything posted by Paul@SWZ
  1. with the engine off can you turn the fan easily when warm ? try it cold you should feel the difference
  2. as long as you drive it steady !
  3. as above the supra lot are generally there so would be nice to roll up in a few zeds sunday evening maybe ? or a BBQ at my place if interested
  4. best advice i can give is dont get one ! they eat transfer boxes and are even more complicated than the zed but are quite nice to drive
  5. unfortunately yes :sleep:
  6. depends if you have the nipple on the inner wing ?
  7. no pre airbags dont have those yellow discs infact the canceller should be on there behind the yellow disc !
  8. surely mike at MJP sells these ?
  9. god you want it all lol you will have to fit an older style from a non airbag version
  10. have you back bled it i find its the easiest way and have you got original piping ie a bleed nipple on the inner wing by hicas solenoid ?
  11. that yellow bit is the ring for the airbag you can remove that
  12. im gonna take a zed to my boat in spain if someone wants a roadtrip its 1400 miles though !
  13. a mate of mine was stopped in a loan porsche from dick lovett because the plates on it were registered to a fiat 500 pop non the less he got compensation from porsche because they had made the plates wrong. shows how easy it is though lol
  14. did you change the pressure plate ? also if pipes have air in it can cause all sorts of probs. just fit new master theyre not expensive ! is there an air pipe that goes through the bulkhead just above the master cylinder ?
  15. go for it with a years warranty you cant really go wrong
  16. 3 main ways 1) chipped ecu 2) speed converter 3) UK speedo as groover says you need to fool the ecu by changing speed signal or remove the limiter via a chipped ecu
  17. you will be gutted if he has had an accident or something !
  18. has he fitted a servo assisted master ? takes about 30 mins to change
